UI suggestion: select all/none
Traveler2032
#1 Post by Traveler2032 » Wed Mar 01, 2023 8:51 pm
I am ripping my BLu-ray collection, and on Hunger Games: Mockingjay 1 there are hundreds of entries for the chapters.
It would be cool to be able to do "Select None" then just manually select the one I want, instead of having to click every one to deselect manually.
Ezatoka
Re: UI suggestion: select all/none
#2 Post by Ezatoka » Wed Mar 01, 2023 9:23 pm
You mean like this?
#3 Post by d00zah » Wed Mar 01, 2023 9:48 pm
And if you were to install Java per this discussion...
"If MakeMKV can sniff out the main feature, it will move its play list to the top, with a comment of "(FPL_MainFeature)" next to it in the selection window (left part of screen)."
