UI suggestion: select all/none
Traveler2032
I am ripping my BLu-ray collection, and on Hunger Games: Mockingjay 1 there are hundreds of entries for the chapters.
It would be cool to be able to do "Select None" then just manually select the one I want, instead of having to click every one to deselect manually.
Ezatoka
Re: UI suggestion: select all/none
You mean like this?
And if you were to install Java per this discussion...
"If MakeMKV can sniff out the main feature, it will move its play list to the top, with a comment of "(FPL_MainFeature)" next to it in the selection window (left part of screen)."
