#8011 Post by RESET_9999 » Mon Feb 27, 2023 11:12 pm
jayper wrote: Mon Feb 27, 2023 10:44 pm I went through the Hybrid maker and removed four frames. Is there anything more to it than that?
nothing more to do... which movie is it?
jayper
#8012 Post by jayper » Mon Feb 27, 2023 11:47 pm
RESET_9999 wrote: Mon Feb 27, 2023 11:12 pm
Thanks for the reassurance.
Harry Potter and the Sorcerer's Stone. MKV file made with MakeMKV has 219173 frames.
yossSP
#8013 Post by yossSP » Mon Feb 27, 2023 11:53 pm
RESET_9999 wrote: Mon Feb 27, 2023 5:18 pm
LV8HD wrote: Mon Feb 27, 2023 5:04 pm @RESET_9999 What do you think about Auto Generated Dolby Vision?
I mean, usually, behind every grade there's a human eye that checks the grade result often with the supervision of the movie director himself. So my question is: When we do custom grades (auto generated with DaVinci), is the movie director intent of watching the movie preserved? if so, is it really that better than having standard HDR10?
L1 metadata is generated by an algorithm(it just map the hdr grade) and only the L2 trims are done manually so the intended look is preserved.
So, is this generated Dolby Vision really better than having standard HDR10? well, I really though that it couldn't beat the quality of the source file.
#8014 Post by RESET_9999 » Mon Feb 27, 2023 11:58 pm
jayper wrote: Mon Feb 27, 2023 11:47 pm Harry Potter and the Sorcerer's Stone. MKV file made with MakeMKV has 219173 frames.
Thanks, I just checked mine and it's in sync.
But it is better to always verify the scene cut when you inject someone else RPU.
#8015 Post by RESET_9999 » Tue Feb 28, 2023 12:01 am
yossSP wrote: Mon Feb 27, 2023 11:53 pm So, is this generated Dolby Vision really better than having standard HDR10? well, I really though that it couldn't beat the quality of the source file.
Of course, you send brightness information(L1 min avg and max) about the content to the TV shot by shot.
So the tone mapping is a lot superior than what you get with the static HDR tone mapping curve because the TV knows in advance how the next shot will be.
jayper
#8016 Post by jayper » Tue Feb 28, 2023 12:03 am
RESET_9999 wrote: Mon Feb 27, 2023 11:58 pm But it is better to always verify the scene cut when you inject someone else RPU.
When you say "verify the scene cut" do you mean verify the frame counts of the video file and the rpu, like I did? Or is that a specific process I can run with the tool?
uhdiznotenough4mee
#8017 Post by uhdiznotenough4mee » Tue Feb 28, 2023 12:07 am
Be careful. You need to use US UHD and not EUR UHD. The source for the DV WEB-DL is the American version with Harry Potter and the Sorcerer's Stone, EUR UHD is Harry Potter and the Philosopher's Stone. Some scenes were refilmed between the two versions and therefore DV from one wouldn't exactly match with another.
jayper
#8018 Post by jayper » Tue Feb 28, 2023 12:09 am
uhdiznotenough4mee wrote: Tue Feb 28, 2023 12:07 am
Thanks for the tip. I have the US UHD.
#8019 Post by RESET_9999 » Tue Feb 28, 2023 12:10 am
jayper wrote: Tue Feb 28, 2023 12:03 am When you say "verify the scene cut" do you mean verify the frame counts of the video file and the rpu, like I did?
oh by 4 frames you meant the script complained about a framecount mismatch when injecting the RPU??
if yes, then it is normal to have a framecount mismatch because it's rarely the same as the WEB-DL. What matter is if the rpu scene cut match your bluray scene cut.
workflow is (2-4) and check the animated gif ("Verify DV synchronization.gif") in the tutorial folder.
jayper
#8020 Post by jayper » Tue Feb 28, 2023 12:14 am
RESET_9999 wrote: Tue Feb 28, 2023 12:10 am oh by 4 frames you meant the script complained about a framecount mismatch when injecting the RPU??
No, I opened the created MKV in StaxRip to verify the frame count of the MKV. I also ran the 2-2 workflow to view the frame count of the RPU. I noticed the four frame distance and then when running the 1-1 Hybrd workflow, I re-synced the RPU by removing 4 frames.
Thanks very much, I will check that one out! I had no idea it existed. Thank you.
#8021 Post by RESET_9999 » Tue Feb 28, 2023 12:19 am
jayper wrote: Tue Feb 28, 2023 12:14 am No, I opened the created MKV in StaxRip to verify the frame count of the MKV. I also ran the 2-2 workflow to view the frame count of the RPU. I noticed the four frame distance and then when running the 1-1 Hybrd workflow, I re-synced the RPU by removing 4 frames.
I see, then you didn't have to remove 4 frames. You still should always verify sync with (2-4)
jayper
#8022 Post by jayper » Tue Feb 28, 2023 12:25 am
Thanks again for all the help today. I will verify with 2-4 and try again. Thanks so much.
jayper
#8023 Post by jayper » Wed Mar 01, 2023 5:55 pm
I watch the film last night and I honestly don't think it has ever looked better. I've seen it so many times at this point, and I was blown away. It'd been a few years, so maybe I am out of touch with the HDR10 grade... I was also really focused on colors and the presentation, so maybe there's a bit of placebo effect happening, but I was quite happy. One of these nights, I need to try and flip flop between the HDR10 and DV for comparison. Thanks again for all the help!
Gatorman
#8024 Post by Gatorman » Wed Mar 01, 2023 8:02 pm
@RESET_9999
Is this a video that might benefit from a Resolve generated RPU? Original file is BL+FEL+RPU.
Video P7 to P8_DoVi_plot.png (105.43 KiB) Viewed 17822 times
#8025 Post by RESET_9999 » Wed Mar 01, 2023 8:36 pm
Gatorman wrote: Wed Mar 01, 2023 8:02 pm @RESET_9999
not sure i understand your question... Why would you generate DV when you have the original retail metadata?
