Can't get MakeMKV to stop skipping Hey Arnold! titles
jrico2
Post by jrico2 »
I am trying to rip Disc 1 of the Hey Arnold! complete series.There are 10 episodes on this disc and MakeMKV keeps skipping all of the even-numbered titles with messages about each title being equal to the one before it:
Title #04 in VTS 3 is equal to title #03 and was skipped
Title #06 in VTS 4 is equal to title #05 and was skipped
Title #08 in VTS 5 is equal to title #07 and was skipped
Title #10 in VTS 6 is equal to title #09 and was skipped
Title #12 in VTS 7 is equal to title #11 and was skipped
Note that it thinks 4 is equal to 3, 6 to 5, etc.
I did some googling and have come across people recommending Manual DVD Mode as a solution to this, but it's not working for me (or I'm not using it correctly?). I enabled Manual Mode, and checked the "Open DVD Manually" box before beginning the scan. The scan produces the following Title Information:
Title information
1: 1/1 - 1 chapter(s) 0:00:15 1 cell(s)
2: 2/1 - 1 chapter(s) 0:00:00 1 cell(s)
3: 3/1 - 4 chapter(s) 0:23:51 4 cell(s)
4: 3/2 - 4 chapter(s) 0:23:51 4 cell(s)
5: 4/1 - 4 chapter(s) 0:23:27 4 cell(s)
6: 4/2 - 4 chapter(s) 0:23:27 4 cell(s)
7: 5/1 - 4 chapter(s) 0:23:39 4 cell(s)
8: 5/2 - 4 chapter(s) 0:23:39 4 cell(s)
9: 6/1 - 4 chapter(s) 0:23:39 4 cell(s)
10: 6/2 - 4 chapter(s) 0:23:39 4 cell(s)
11: 7/1 - 4 chapter(s) 0:23:36 4 cell(s)
12: 7/2 - 4 chapter(s) 0:23:36 4 cell(s)
I then entered the following string to describe the titles I want to open:
3 4 5 6 7 8 9 10 11 12
However, all of the even number titles are still being skipped. I added debug logging and this is the output:
MakeMKV v1.17.3 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/david/MakeMKV_log.txt
Optical drive "DVD+R-DL TSSTcorp CDDVDW SN-208DN SC00 R92L6YLD4008WKd" opened in OS access mode.
Open DVD manually : "3 4 5 6 7 8 9 10 11 12"
Cells 4-4 were removed from title end
Title #3 was added (3 cell(s), 0:23:49)
Title #4 was added (3 cell(s), 0:23:49)
Title #5 was added (3 cell(s), 0:23:25)
Title #6 was added (3 cell(s), 0:23:25)
Title #7 was added (3 cell(s), 0:23:37)
Title #8 was added (3 cell(s), 0:23:37)
Title #9 was added (3 cell(s), 0:23:37)
Title #10 was added (3 cell(s), 0:23:37)
Title #11 was added (3 cell(s), 0:23:35)
Title #12 was added (3 cell(s), 0:23:35)
DEBUG: Code 233 at /6aic2kJIdSBCgN4f97Gz5av:0
Any idea what I can do to get all of these titles??
Re: Can't get MakeMKV to stop skipping Hey Arnold! titles
What happens if you try opening a single episode when using manual mode?
Also, MakeMKV has multiple DVD opening modes. Sometimes switching to a different opening mode helps.
joseph_maclure
Post by joseph_maclure »
I had this before also. Try manual mode and do one title at a time.
If that doesn't work it could be the disc, I spent hours trying to figure out why this was happening to two discs in a season. Bought newer copies and it worked on them...
