Jericho S01E02 missing off DvD
taldren
Post by taldren »
Purchased "Jericho: The Complete Series" DvD set off Amazon.com.
Disc 1 only showed 3 episodes, but when I play the disc in the same drive via VLC I can see/watch 4 episodes. The missing episode happens to be the second.
Log shows the following:
Debug log started at Mon Feb 27 17:20:56 2023 , written by MakeMKV v1.17.3 win(x64-release)
001005:0000 MakeMKV v1.17.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxx/MakeMKV_log.txt
DEBUG: Code 3 at 'W5#or0UspRy]J7I('S_3yx3:29395310
SDF  v097: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIK07KBRF0645
001011:0000 Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #4 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #5 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #6 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #7 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #8 does not match one in IFO header.
Launching D:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
DEBUG: Code 0 at E9c-$0{W(c6Jm.J'p|na:29396460
003028:0000 Title #1 was added (7 cell(s), 0:40:27)
003028:0000 Title #3 was added (9 cell(s), 0:44:35)
003028:0000 Title #4 was added (9 cell(s), 0:40:44)
003025:0000 Title #14/1 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14/2 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14/3 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14/5 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14/6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14/7 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003038:0000 Cells 4-4 were removed from title end
003028:0000 Title #16 was added (3 cell(s), 0:04:05)
003038:0000 Cells 2-2 were removed from title end
003028:0000 Title #18 was added (1 cell(s), 0:05:02)
003025:0000 Title #19 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #19/1 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #19/2 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #21 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
MMBDINST: Launching D:\Program Files (x86)\MakeMKV/makemkvcon64.exe
MMBDINST: HELLO 00
Put libmmbd.dll -> C:\Program Files (x86)\VideoLAN\VLC/libmmbd.dll
MMBDINST: MMBD installer exiting.
Application exited at Mon Feb 27 17:36:33 2023
Re: Jericho S01E02 missing off DvD
Post by d00zah »
taldren wrote:
Mon Feb 27, 2023 5:55 pm
MMBDINST: HELLO 00
2 things to try:
DVD opening modes - CellWalk, CellTrim, CellFull
Manual Mode
taldren
Post by taldren »
CellTrim method worked. Thank you.
AshenTemper
Post by AshenTemper »
I just wanted to say thanks as well. Had the exact same problem with Jericho, Disc 1, Episode 2 not showing up, and using CellTrim worked.
