Fatal error occurred, program will now exit - 1.17.3
Re: Fatal error occurred, program will now exit - 1.17.3
I have the same Problem with HD DVDs and I cant go back to an older version
There have been other reports of problems with HD DVDs since 1.17 came out. Possibly earlier versions.
https://makemkv.com/download/old/ is where you can find old versions of MakeMKV.
If you have a paid-for license you can use older versions of MakeMKV.
