Can't rip Star Wars IV DVD
Icanseestars
Post by Icanseestars »
I've been trying to rip Star Wars IV from this box set but MakeMKV cant create a file from it stating copy failed at the end. Even using AnyDVD and ripping to the HD cannot get round it, the DVD is weirdly made I'm guessing. MakeMKV detects 5 angles at 6.1GB each and it fails if I try to rip angle 1 no matter what.
This is what it says after opening the disc
MakeMKV v1.4.6 beta win(x86-release) started
Cells 76-end were skipped due to cell commands (structure protection?)
Complex multiplex encountered - 2 cells and 1241 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #0 was added (67 cell(s), 1:59:09)
Angle #2 was added for title #0
Angle #3 was added for title #0
Angle #4 was added for title #0
Angle #5 was added for title #0
Title #1 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 with special attributes was skipped
Title #16 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
After copying it goes all the way right to the end then says "Copy complete. 0 titles saved, 1 failed." then it brings me back to the previous screen in MakeMKV only now angle 1 is gone from the selection.
It is at all possible to correct this ?
Re: Can't rip Star Wars IV DVD
Post by mike admin »
Please enable "log debug messages" in preferences, restart the app and try to copy disc again. Then share the produced log file.
Icanseestars
Here is the log file, hope it helps.
Debug log started at Thu Aug 06 09:20:52 2009 , written by MakeMKV v1.4.6 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Bob/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003017:000000:0000 Cells 76-end were skipped due to cell commands (structure protection?)
003046:000000:1000 Complex multiplex encountered - 2 cells and 1241 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003036:000000:0000 Title #0 was added (67 cell(s), 1:59:09)
003048:000000:0000 Angle #2 was added for title #0
003048:000000:0000 Angle #3 was added for title #0
003048:000000:0000 Angle #4 was added for title #0
003048:000000:0000 Angle #5 was added for title #0
003020:000000:0000 Title #1 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #2 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #3 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #4 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #5 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #6 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #7 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #8 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #9 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #10 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #11 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #12 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #13 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #14 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003014:000000:0000 Title #15 with special attributes was skipped
003020:000000:0000 Title #16 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001012:000000:0020 FAILURE: Code 2 at R/CJ!rRC50zA>2kT{:29393907
001012:000000:0020 FAILURE: Code 0 at R/CJ!rRC50zA>2kT{:121264970
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory C:/Movie dtemp/STAR_WARS_EPISODE_IV
001011:000000:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: frame->timecode>=cluster_timecode
005003:000000:0000 Failed to save title 0 to file C:/Movie dtemp/STAR_WARS_EPISODE_IV/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Application exited at Thu Aug 06 09:30:18 2009
