tjayz
#7981 Post by tjayz » Mon Feb 13, 2023 10:02 pm
RESET_9999 wrote:
Tue Apr 07, 2020 2:15 pm
sureshm3 wrote:
Tue Apr 07, 2020 10:36 am
Where can we download previous version (mp4muxer_64bit.exe)? Only v1.01 is available on github and that doesnt seem to work on my C9.
https://drive.google.com/file/d/1vuAO2L ... sp=sharing
Looking to get this version back for testing purposes. It no longer exists online anywhere... Link above is dead, as expected it is ancient. Been following this post for years, just never commented and apparently am unable to PM as a new member. Much obliged for anyone who can assist, thanks.
UBP-X800M2 / LG OLED CX / NAD M17 V2i
#7982 Post by RESET_9999 » Mon Feb 13, 2023 10:31 pm
https://mega.nz/file/G4ty0B7Y#FJYI2ufdj ... CbvEnF0tE8
tjayz
#7983 Post by tjayz » Tue Feb 14, 2023 1:01 am
Thanks for your prompt reply and thrilled you still have this! While I ran -v on this and confirmed it is 1.0.0 and while running it task manager shows 64bit, I am certain there was a version _64 which that when you ran -h it had settings absent from this version. I believe it had dv 8 and --dv-bl-compatible-id flags while this version does not, likewise it could only be called in cmd by mp4muxer_64 not mp4muxer. Do you still have this version buried somewhere as well? Your help is much appreciated!
duder
#7984 Post by duder » Thu Feb 16, 2023 4:40 pm
Hi Guys!
Was trying to convert p7 st-dl mkv file to dt-dl m2ts file to watch with Sony-x800m2. The original blu-ray structure shows that MEL is only 78 kbps (0.10%). After using Dovi Tools 4-3 path I have two files BL and El. But the latter is 0 kb in size. And as a result tsMuxer does not detect it(.
Thinking that such small MEL file is not a considerable improvement picture-wise I decided to go with p8. What option should I choose in DoVi Tools? Trying some I got *.ts file but with no DV mentioned in media-info or in player OSD, only HDR.
#7985 Post by RESET_9999 » Thu Feb 16, 2023 5:19 pm
Hi Guys!
are you sure the MKV got DV metadata? Sounds like it doesnt.
For ST P7 mkv to P8 TS ---> (4-2)
Dinst
#7986 Post by Dinst » Thu Feb 16, 2023 6:24 pm
Has anybody got a link to a decent tutorial for generating Dolby Vision using Davinci Resolve?
duder
#7987 Post by duder » Fri Feb 17, 2023 2:23 pm
Hi Guys!
You are absolutely right. The mkv file has no DoVi info( Somehow I missed it(
Trees
#7988 Post by Trees » Sun Feb 19, 2023 11:41 am
Hi guys. Does anyone know if it's possible to add H.265 2160p WEB-DL HDR10 and DV to a H.265 2160p SDR remux? Unfortunately, the UHD is SDR whereas the WEB-DL is available in HDR10 and DV.
TheEqualizer
#7989 Post by TheEqualizer » Fri Feb 24, 2023 11:53 am
RESET_9999, please tell me how you can add more than one audio track or subtitles using scripts, 7-3-1 mode.
Or in another way without using scripts, thank you in advance
#7990 Post by RESET_9999 » Fri Feb 24, 2023 3:27 pm
Wow I didnt know some people were still using dual track dual layer MP4... I didnt touch this workflow since i made the script and dont really have a plan to make changes here...
you can do it manually with the old mp4muxer:
mp4muxer_path --dv-profile 7 --input-file BL.hevc --input-file EL.hevc --input-file audio1.ec3 --input-file audio2.ec3 --output-file output.mp4
then if you want to add subs:
mp4box_path -add output.mp4 -add subs.srt  -brand mp43isom -ab dby1 output_subs.mp4
TheEqualizer
#7991 Post by TheEqualizer » Fri Feb 24, 2023 6:05 pm
RESET_9999 wrote: Wow I didnt know some people were still using dual track dual layer MP4...
Wait, isn't it better than an 8 profile without an EL layer? Perhaps I didn't quite understand you, please explain!
#7992 Post by RESET_9999 » Fri Feb 24, 2023 7:16 pm
yes, it is better than P8 even though i don't see much difference in PQ (not even the ones with juicy 15-20mb/s layer). I just thought everybody moved to TS/M2ts container for dual-track DV.
https://slow.pics/c/V4VSWPDy
https://slow.pics/c/dXBSzGzE
dom61
#7993 Post by dom61 » Fri Feb 24, 2023 7:47 pm
Good evening.
I have exported HDR 10+ and Dolby Vison metadata via DaVinci Resolve.
I need to convert these files via DoVi, kindly can you point me to a link where to download it?
Thank you
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
#7994 Post by RESET_9999 » Fri Feb 24, 2023 8:19 pm
you can use the script in my signature (workflow 1-1) to inject both metadata. Or use the Dovi_tool and HDR10plus_tool to inject manually, you can find these tools on quietvoid's GitHub.
see my youtube channel (link in my signature), i made a video tutorial a while ago.
if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected :)
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWA
dom61
#7995 Post by dom61 » Fri Feb 24, 2023 8:46 pm
Thank you very much for the valuable information.
My PC Ryzen 7950X
