Wait, isn't it better than an 8 profile without an EL layer? Perhaps I didn't quite understand you, please explain!RESET_9999 wrote: Wow I didnt know some people were still using dual track dual layer MP4...
TheEqualizer
yes, it is better than P8 even though i don't see much difference in PQ (not even the ones with juicy 15-20mb/s layer). I just thought everybody moved to TS/M2ts container for dual-track DV.TheEqualizer wrote: ↑Fri Feb 24, 2023 6:05 pmWait, isn't it better than an 8 profile without an EL layer? Perhaps I didn't quite understand you, please explain!
https://slow.pics/c/V4VSWPDy
https://slow.pics/c/dXBSzGzE
Good evening.
I have exported HDR 10+ and Dolby Vison metadata via DaVinci Resolve.
I need to convert these files via DoVi, kindly can you point me to a link where to download it?
Thank you
Thank you
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
My PC Ryzen 7950X
you can use the script in my signature (workflow 1-1) to inject both metadata. Or use the Dovi_tool and HDR10plus_tool to inject manually, you can find these tools on quietvoid's GitHub.
see my youtube channel (link in my signature), i made a video tutorial a while ago.
if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWARe: Dolby Vision now possible through MP4 Mux.
Thank you very much for the valuable information.RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pmHi,
My PC Ryzen 7950X
My PC Ryzen 7950X
Thank you very muc for the RPU files, I just want to ask if all of them are generated in DV or if some of them comes from iTunes (those one that are OK according to your table).RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pmif you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected
There's "p5 to p8" in the filename when the source is retail WEB-DL. Everything else is Resolve generated.
Amazing work! Thank you!RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pm
Would it be possible to allow XML and RPU files for the L2 export feature and add a graphing feature? (2-6)
Hi !
Why @RESET_9999 did you stop creating zip with all the tools for your script ?
RPU input is already supported in (2-6) but I will add XML input support in the next version.
as for a graph plot feature for L2, I don't know how to do that but i can do some research.
If I want to generate DV metadata for HLG video, is it the same workflow as for HDR10 video or do I have to change something in Davinci Resolve?
there's a resolve preset for hlg in the script tutorial folder.
Then the workflow is the same and when you input an HLG base layer with (1-1), the script will make/inject a p8.4 RPU.
my script will only work if your input has proper HLG flag. If not then do it manually with the dovi_tool mode 4
Fantastic work! Just one question: Are the P5toP8-bin already edited regarding delays and L5 as listed in Web-DL overview? I am asking, because some filenames have a hint to the delay (The.DaVinci.Code -24), some have not (Philadelphia), although both have a delay according to your WEB-DL-list.RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pm
yes, they are all in sync. You can ignore the delay notes in the filename.
If you're still not sure (different bluray region, different cut), you can use the script (2-4) and verify if the scene cut matches your bluray.
