RESET_9999, please tell me how you can add more than one audio track or subtitles using scripts, 7-3-1 mode.
Or in another way without using scripts, thank you in advance
Wow I didnt know some people were still using dual track dual layer MP4... I didnt touch this workflow since i made the script and dont really have a plan to make changes here...TheEqualizer wrote: ↑Fri Feb 24, 2023 11:53 amRESET_9999, please tell me how you can add more than one audio track or subtitles using scripts, 7-3-1 mode.
you can do it manually with the old mp4muxer:
mp4muxer_path --dv-profile 7 --input-file BL.hevc --input-file EL.hevc --input-file audio1.ec3 --input-file audio2.ec3 --output-file output.mp4
mp4box_path -add output.mp4 -add subs.srt -brand mp43isom -ab dby1 output_subs.mp4
Wait, isn't it better than an 8 profile without an EL layer? Perhaps I didn't quite understand you, please explain!RESET_9999 wrote: Wow I didnt know some people were still using dual track dual layer MP4...
yes, it is better than P8 even though i don't see much difference in PQ (not even the ones with juicy 15-20mb/s layer). I just thought everybody moved to TS/M2ts container for dual-track DV.TheEqualizer wrote: ↑Fri Feb 24, 2023 6:05 pmWait, isn't it better than an 8 profile without an EL layer? Perhaps I didn't quite understand you, please explain!
https://slow.pics/c/V4VSWPDy
https://slow.pics/c/dXBSzGzE
Good evening.
I have exported HDR 10+ and Dolby Vison metadata via DaVinci Resolve.
I need to convert these files via DoVi, kindly can you point me to a link where to download it?
Thank you
Thank you
Zidoo Z9X | HiMedia Q5 Pro and Q10 Pro | ZDMC 20.1 | Remote WeChip | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C
My PC Ryzen 7950X
My PC Ryzen 7950X
you can use the script in my signature (workflow 1-1) to inject both metadata. Or use the Dovi_tool and HDR10plus_tool to inject manually, you can find these tools on quietvoid's GitHub.
see my youtube channel (link in my signature), i made a video tutorial a while ago.
if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected
![Smile :)](./images/smilies/icon_smile.gif)
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWA
Thank you very much for the valuable information.RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pmHi,
My PC Ryzen 7950X
My PC Ryzen 7950X
Thank you very muc for the RPU files, I just want to ask if all of them are generated in DV or if some of them comes from iTunes (those one that are OK according to your table).RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pmif you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected
There's "p5 to p8" in the filename when the source is retail WEB-DL. Everything else is Resolve generated.
Amazing work! Thank you!RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pm
Would it be possible to allow XML and RPU files for the L2 export feature and add a graphing feature? (2-6)
Hi !
Why @RESET_9999 did you stop creating zip with all the tools for your script ?
RPU input is already supported in (2-6) but I will add XML input support in the next version.
as for a graph plot feature for L2, I don't know how to do that but i can do some research.
If I want to generate DV metadata for HLG video, is it the same workflow as for HDR10 video or do I have to change something in Davinci Resolve?
there's a resolve preset for hlg in the script tutorial folder.
Then the workflow is the same and when you input an HLG base layer with (1-1), the script will make/inject a p8.4 RPU.
my script will only work if your input has proper HLG flag. If not then do it manually with the dovi_tool mode 4
