TheEqualizer
#7996 Post by TheEqualizer » Fri Feb 24, 2023 11:53 am
RESET_9999, please tell me how you can add more than one audio track or subtitles using scripts, 7-3-1 mode.
Or in another way without using scripts, thank you in advance
#7997 Post by RESET_9999 » Fri Feb 24, 2023 3:27 pm
Wow I didnt know some people were still using dual track dual layer MP4... I didnt touch this workflow since i made the script and dont really have a plan to make changes here...
you can do it manually with the old mp4muxer:
mp4muxer_path --dv-profile 7 --input-file BL.hevc --input-file EL.hevc --input-file audio1.ec3 --input-file audio2.ec3 --output-file output.mp4
then if you want to add subs:
mp4box_path -add output.mp4 -add subs.srt  -brand mp43isom -ab dby1 output_subs.mp4
TheEqualizer
#7998 Post by TheEqualizer » Fri Feb 24, 2023 6:05 pm
RESET_9999 wrote: Wow I didnt know some people were still using dual track dual layer MP4...
Wait, isn't it better than an 8 profile without an EL layer? Perhaps I didn't quite understand you, please explain!
#7999 Post by RESET_9999 » Fri Feb 24, 2023 7:16 pm
yes, it is better than P8 even though i don't see much difference in PQ (not even the ones with juicy 15-20mb/s layer). I just thought everybody moved to TS/M2ts container for dual-track DV.
https://slow.pics/c/V4VSWPDy
https://slow.pics/c/dXBSzGzE
dom61
#8000 Post by dom61 » Fri Feb 24, 2023 7:47 pm
Good evening.
I have exported HDR 10+ and Dolby Vison metadata via DaVinci Resolve.
I need to convert these files via DoVi, kindly can you point me to a link where to download it?
Thank you
Zidoo Z9X | HiMedia Q5 Pro and Q10 Pro | ZDMC 20.1 | Remote WeChip | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C
My PC Ryzen 7950X
#8001 Post by RESET_9999 » Fri Feb 24, 2023 8:19 pm
you can use the script in my signature (workflow 1-1) to inject both metadata. Or use the Dovi_tool and HDR10plus_tool to inject manually, you can find these tools on quietvoid's GitHub.
Dinst wrote:
Thu Feb 16, 2023 6:24 pm
Has anybody got a link to a decent tutorial for generating Dolby Vision using Davinci Resolve?
see my youtube channel (link in my signature), i made a video tutorial a while ago.
if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected :)
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWA
dom61
#8002 Post by dom61 » Fri Feb 24, 2023 8:46 pm
Thank you very much for the valuable information.
My PC Ryzen 7950X
powdeau
#8003 Post by powdeau » Fri Feb 24, 2023 9:21 pm
Thank you very muc for the RPU files, I just want to ask if all of them are generated in DV or if some of them comes from iTunes (those one that are OK according to your table).
#8004 Post by RESET_9999 » Fri Feb 24, 2023 9:22 pm
There's "p5 to p8" in the filename when the source is retail WEB-DL. Everything else is Resolve generated.
Dinst
#8005 Post by Dinst » Sat Feb 25, 2023 12:13 pm
Amazing work! Thank you!
Would it be possible to allow XML and RPU files for the L2 export feature and add a graphing feature? (2-6)
Draco1544
#8006 Post by Draco1544 » Sat Feb 25, 2023 2:35 pm
Hi !
Why @RESET_9999 did you stop creating zip with all the tools for your script ?
#8007 Post by RESET_9999 » Sat Feb 25, 2023 3:28 pm
RPU input is already supported in (2-6) but I will add XML input support in the next version.
as for a graph plot feature for L2, I don't know how to do that but i can do some research.
Dinst
#8008 Post by Dinst » Sat Feb 25, 2023 8:30 pm
Hi !
https://docs.google.com/document/d/1L3e ... HdtF7/edit
powdeau
#8009 Post by powdeau » Sat Feb 25, 2023 10:06 pm
If I want to generate DV metadata for HLG video, is it the same workflow as for HDR10 video or do I have to change something in Davinci Resolve?
#8010 Post by RESET_9999 » Sun Feb 26, 2023 2:06 pm
there's a resolve preset for hlg in the script tutorial folder.
Then the workflow is the same and when you input an HLG base layer with (1-1), the script will make/inject a p8.4 RPU.
my script will only work if your input has proper HLG flag. If not then do it manually with the dovi_tool mode 4
