some programs do store a DVD image as an folder of the DVD (with all files inside) and the extension ".dvdmedia" for the folder. Such folders are shown as a "dvd file" in the finder, and a double click do open it in the DVD Player.
So, it would great if MakeMKV would also recognize *.dvdmedia folders. (Should be simple: just allow to select those entries, and then scan xxx.dvdmedia/VIDEO_TS/VIDEO_TS.IFO).
Thanks in advance.
/ALeX.
Support for *.dvdmedia DVD Images
Re: Support for *.dvdmedia DVD Images
If you delete the ".dvdmedia" file extension name off the end, it will turn into a regular folder.
Yes, I know that. But why not make it easy?
That isn't easy?
And yes, I know that would be more convenient.
I would second the request to natively support the .dvdmedia extension. Granted it's easy to rename, but it would be nice if makemkv recognized it without having to take the extra step to rename.
Keep up the great work though, makemkv has become a major component of my dvd media server project.
