A bit of a niche dvd set but the first disc doesn't want to rip the second title
Attached is the log for the rip, any advice would be great. All of the discs have warned of AV sync issues but this is the only one that can't save the title
Any advice would be fantastic, thanks a lot!
Steve Forte Gambling Protection Series Disc 1
t0tal
- MakeMKV_log.txt
- (24.4 KiB) Downloaded 345 times
Re: Steve Forte Gambling Protection Series Disc 1
Debug log started at Thu Feb 23 00:24:53 2023 , written by MakeMKV v1.17.3 win(x64-release)
001005:0000 MakeMKV v1.17.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\****/MakeMKV_log.txt
DEBUG: Code 3 at 'W5#or0UspRy]J7I('S_3yx3:29395310
SDF v097: HL-DT-ST_BD-RE__BH16NS60_1.02_212005081014_KL3J4FA2906
001011:0000 Using LibreDrive mode (v06.3 id=AC9AE4790E7F)
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
003028:0000 Title #1 was added (37 cell(s), 0:51:03)
003028:0000 Title #2 was added (46 cell(s), 1:02:30)
005014:0000 Saving 2 titles into directory file://D:/Video/V1
005001:0308 File D:/Video/V1/A1_t00.mkv already exist. Do you want to overwrite it?
005001:0308 File D:/Video/V1/B1_t01.mkv already exist. Do you want to overwrite it?
004004:0000 The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1625999360, attempting to work around
004007:0010 AV synchronization issues were found in file 'file://D:/Video/V1/A1_t00.mkv' (title #1)
004047:0010 AV sync issue in stream 0 at 0:34:23.444 : video frame timecode differs by -50.05ms
004008:0010 AV sync issue in stream 1 at 0:34:22.976 with duration of 64ms : audio gap - 2 missing frame(s)
004008:0010 AV sync issue in stream 1 at 0:34:23.104 with duration of 32ms : audio gap - 1 missing frame(s)
004047:0010 AV sync issue in stream 0 at 0:34:23.928 : video frame timecode differs by -33.366ms
004047:0010 AV sync issue in stream 0 at 0:34:24.412 : video frame timecode differs by -16.683ms
004004:0000 The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2134028288, attempting to work around
004008:0010 AV sync issue in stream 1 at 0:45:03.968 with duration of 96ms : audio gap - 3 missing frame(s)
004047:0010 AV sync issue in stream 0 at 0:51:23.713 : video stream has 3 frames with invalid timecodes
004004:0000 The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 83550208, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 83591168, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 83611648, attempting to work around
