I've been ripping DVDs for a little while using Makemkv and then handbrake. In handbrake what is the best preset to use for say Top gun Maverick.
Also is it an advantage to use handbrake over just using Makemkv. TIA
Noob!
MKV versus handbrake
Re: MKV versus handbrake
i mean you dont really need to shrink a dvd any more they are so small
just use makemkv without handbreak 18 TB HDDs are at $12 a TB when they are on a good deal.
i would rather the original quality and take up more space.
I definitely have enough space at 40tb. Same here with quality. Thank you!!!!Billycar11 wrote: Tue Feb 21, 2023 1:37 am i mean you dont really need to shrink a dvd any more they are so small
Handbrake is a transcoder, not a ripper. Even to overcome CSS you have to use a third party library. Many protections can screw with the correct title finding within Handbrake.stevenm56 wrote: Tue Feb 21, 2023 1:22 am Also is it an advantage to use handbrake over just using Makemkv. TIA
Often enough when there is a problem with a DVD in the Handbrake forums, it's "use MakeMKV first" and then "that worked!"
