Unable to RIP 4K, missing keys?
pingopallino
#1 Post by pingopallino » Sun Feb 19, 2023 4:41 pm
Hi, first time posting here.
I have several 4K discs and a patched archgon drive (UHD ready).
On thursday I tried to rip the movie "The Birds" in 4K (italian version) and the output that I get is the following:
MakeMKV v1.17.3 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:3'
Saved AACS dump file as /home/boh/.MakeMKV/MKB20_v72_The_Birds_4599.tgz
So I sent on the same day the generated dump file to the mail address. Today I tried again, but I got the same message.
The only thing that worries me is that I don't get the output "Using LibreDrive mode", but maybe it is normal with the version 1.17.3.
The option "Enable Internet access" is and was enabled.
Do I have to wait for the keys to be generated or the problem lies elsewhere?
Here are the information about the drive:
OS device name: /dev/sr1
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 77
Firmware version: 1.03
RemasterRichie
Re: Unable to RIP 4K, missing keys?
#2 Post by RemasterRichie » Mon Feb 20, 2023 4:02 am
Sometimes it takes a few days before the dumps are available. Try it every day until it hits, but usually it works after 1-3 days.
#3 Post by Billycar11 » Mon Feb 20, 2023 5:08 am
pingopallino wrote: Sun Feb 19, 2023 4:41 pm Hi, first time posting here.
Revision: 1.03
Serial number:
the error here is a pass through error or makemkv sometimes does not like 1.03 on linux dockers for some reason and 1.00 will work
try 1.00 if issue solved then your good if not then you have a pass through error
pingopallino
#4 Post by pingopallino » Mon Feb 20, 2023 9:45 am
Thank you!
Yes, you are right. I tried it on Windows and MakeMKV was "Using LibreDrive mode" and was able to download the new keys.
I flashed the 1.03 firmware, since it is the recommended one in the guide. I do not know where to find the 1.00.
I would like to rip my discs using Linux, because it is my main operating system; but using Windows from time to time for 4K discs is not a problem.
Should I flash it or a new version of MakeMKV could resolve the issue?
#5 Post by Billycar11 » Mon Feb 20, 2023 8:10 pm
pingopallino wrote: Mon Feb 20, 2023 9:45 am
Thank you!
1.00 is in the de firmware pack in the guide
Dont know if makemkv can fix it unless you show us it's not a passthrough issue on linux
