Does HDDVD still work?
bill_w
Post by bill_w »
I have been offered a relative's HDDVD collection of about 80 discs. I don't have a drive, so I will need to spend about $50 to get one. Before I do that, I wanted to make sure that MakeMKV can still rip them. I searched the forum and it looked like maybe recent versions no longer support this format, but I didn't see anything conclusive. Thanks!
bill_w
Re: Does HDDVD still work?
Post by bill_w »
I went ahead and gave it a shot and can report success. Ripping HDDVD works just fine under 1.17.1 on Linux with an LG GGC-H20L drive with the exception of a couple of what I assume to be rotted discs.
Baettel
Post by Baettel »
I'm trying this with my HD-DVD drive and discs and I'm seeing issues. Did 1.17.3 stop supporting HD-DVD?
demon
Post by demon »
Can you at least do a "Backup" of the disc?
There have been some posts lately that HD-DVD support is broken in 1.17.3.
viewtopic.php?f=1&t=30243
I don't think that's intentional, just a bug. If you can keep going with 1.17.1 for the time being, that's what you should do.
DreckSoft
Post by DreckSoft »
HD DVD is definitely broken support. At least in 1.17.4.
Some discs fail to open, some discs crash MakeMKV.
The discs can be read using AnyDVD (no it was not active when using MakeMKV)
With 1.16.7 it works.
DreckSoft
Post by DreckSoft »
That was a bit premature. 1.16.7 can open SOME discs. Others still fail.
And: In any case the resulting subtitles are unusable. Especially the subtitle handling could save a lot of time. With other tools, a lot of manual steps are involved.
Did you try 1.17.5? https://makemkv.com/download/
The release notes say there are bug fixes for HD-DVD.
mustang5o
Post by mustang5o »
New to this. I have several HDDVD's that I haven't replaced on Blu-Ray. I presume I need an HD-DVD drive to back them up using makemkv.
