Read failures on multiple discs
Grayfox
Post by Grayfox » Fri Feb 17, 2023 9:35 am
Hi.
I am re-ripping my bluray movies again as the first time time i encoded them down to a smaller file size as I had limited storage space.
But now since I have a 30TB NAS I decided to re-rip them and just leave the streams as is.
But some of the disc are
  • Disc will fail to even be detected
    Disc will fail to detect, but will be detected after several attempts of reinserting the disc
    Disc will be detected but rip will fail at some point
All these discs have been stored in their cases and in a drawer away from any light.
The bottoms are 100% free of any fingerprints, dust, scratches
Apart from the first rip, they've never been taken out of the case until now.
I have tried using my newer Pioneer BDR-XD05 as well as my old LG GGW-H20L drive and the results are the same more or less.
Is their way to fix these discs or are they dead and how can I prevent this from happening to my other discs.
This is the debug output for Startrek: Into Darkness
DEBUG: Code 100864261 at K!bKj*n\NVctKWck&C:121263429
DEBUG: Code 100864261 at K!bKj*n\NVctKWck&C:121262302
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.01 PIDL009105WL' at offset '24722014208'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.01 PIDL009105WL' at offset '24722077696'
udf: node fe/efe failed!
Using LibreDrive mode (v01.0 id=5FB5DFEE2318)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8494104576'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '28121358336'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '16990439424'
DEBUG: Code 100865282 at K!bKj*n\NVctKWck&C:121263429
DEBUG: Code 100865282 at K!bKj*n\NVctKWck&C:121262302
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '28278257664'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '15137550336'
File 00800.mpls was added as title #0
Title #00055.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00056.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00057.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00086.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00058.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00060.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00095.mpls has length of 15 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00094.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00061.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00062.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00063.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00073.mpls has length of 15 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00064.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00066.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00087.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00067.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00068.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00070.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00069.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00074.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00075.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00076.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00077.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00078.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00079.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00080.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00081.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00093.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00082.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00083.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00059.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00084.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00085.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00088.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00089.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00091.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00092.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00090.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00096.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00097.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00098.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00065.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00099.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00103.mpls has length of 15 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00054.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00020.mpls has length of 57 seconds which is less than minimum title length of 900 seconds and was therefore skipped
File 00250.mpls was added as title #1
Title #00250.m2ts has length of 508 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01014.m2ts has length of 325 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01015.m2ts has length of 450 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01016.m2ts has length of 423 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01017.m2ts has length of 363 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #01018.m2ts has length of 344 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00021.m2ts has length of 31 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00022.m2ts has length of 26 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Saving 1 titles into directory /home/grayfox/Videos/Star Trek Into Darkness
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2548101120'
Error 'Posix error - No data available' occurred while reading '/dev/sr1' at offset '2548101120'
DEBUG: Code 1073741885 at K!bKj*n\NVctKWck&C:213131502
DEBUG: Code 100864261 at K!bKj*n\NVctKWck&C:213131502
DEBUG: Code 0 at ?LW5!6Q$%%ns\r~J(; 0:29395471
DEBUG: Code 0 at 86ko25, oe?. 2 }at8u:29394068
DEBUG: Code 0 at ?LW5!6Q$%%ns\r~J(; 0:213131157
DEBUG: Code 0 at ?LW5!6Q$%%ns\r~J(; 0:121262647
DEBUG: Code 1244190 at ?LW5!6Q$%%ns\r~J(; 0:121261773
DEBUG: Code 0 at VmGs_5{K3LgQ8S,>H3&:u:213137068
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file /home/grayfox/Videos/Star Trek Into Darkness/Star Trek Into Darkness.mkv
Encountered 15 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Thank you.
Re: Read failures on multiple discs
Post by Billycar11 » Fri Feb 17, 2023 8:41 pm
Step 1 is always to clean them with a damp lint free microfiber cloth and dry with another.
See if you can exchange the discs with the company if that does not work.
Grayfox
Post by Grayfox » Mon Feb 20, 2023 7:29 am
The discs have been cleaned a few times with a micro fiber cloth.
