I do not know why The 007-The World is Not Enough Region 3 DVD is always failed to be extracted by MakeMKV V1.1.73.
How can i contact with the author of MakeMKV?
I have tried to extract The DVD content from the discs that comes from three different source. None of them is able to be extracted successfully.
it is never successful even i purchased a brand new disc to extract it.
i can provide the error message and screenshot.
i hope that i can get the answer and i would like to provide everything the author needs in order to fix the problem.
anything else needed about the disc can also be provided by me. all you need is to leave me a message here and tell me what you need.
hi ... The 007 The World is Not Enough DVD Region 3
macintosh456789
- 圖片_20230216223038.png (9.11 KiB) Viewed 8063 times
- 圖片_20230216223047.png (56.26 KiB) Viewed 8063 times
Re: hi ... The 007 The World is Not Enough DVD Region 3
Open the Preferences page and turn on extended debug messages. Something is happening that isn't being reported under the short debug code.
macintosh456789
Sorry, I am late.Woodstock wrote: Thu Feb 16, 2023 3:15 pm Open the Preferences page and turn on extended debug messages. Something is happening that isn't being reported under the short debug code.
The Debug Message is here...
MakeMKV v1.17.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Macintosh/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Cells 43-43 were removed from title end
Title #1 was added (42 cell(s), 2:07:52)
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 196864 at d\C_XM&wlJ8e7y:29401497
DEBUG: Code 197120 at d\C_XM&wlJ8e7y:29401497
Cells 2-2 were removed from title end
Title #4 was added (1 cell(s), 0:15:05)
DEBUG: Code 262400 at d\C_XM&wlJ8e7y:29401497
DEBUG: Code 262656 at d\C_XM&wlJ8e7y:29401497
Title #5 was added (1 cell(s), 0:04:01)
DEBUG: Code 327936 at d\C_XM&wlJ8e7y:29401497
DEBUG: Code 328192 at d\C_XM&wlJ8e7y:29401497
Title #6 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 393472 at d\C_XM&wlJ8e7y:29401497
DEBUG: Code 393728 at d\C_XM&wlJ8e7y:29401497
Title #7 was added (1 cell(s), 0:02:18)
Audio stream #2 is identical to stream #1 and was skipped
Audio stream #3 is identical to stream #1 and was skipped
Saving 1 titles into directory C:/Users/Macintosh/Downloads/Video/xxxxx
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file C:/Users/Macintosh/Downloads/Video/xxxxx/B1_t00.mkv
0 titles saved, 1 failed
and i found something interesting...
the issue will be fixed if i choose not to extract english subtitle.
i also tried to extract the subtitle with VobSub.
the english subtitle is able to be extracted by VobSub, nothing is wrong, it works perfectly.
here is the debug text file if you need it.
- MakeMKV_log.txt
- (18.11 KiB) Downloaded 422 times
Leaving out a track (in this case a subtitle) would remove checks for timing on that track, so the overall rip would not fail. Why it is failing on that subtitle is a question. It seems to be failing because the time to display the subtitle is wrong.
Extracting JUST the subtitle may be ignoring the timing. That's something that I can't tell from what we've got. Perhaps the author Mike can pull the information from the debug information.
Theory says it could be cleaned up with a disk cleaning. There are a number of drives that can read stuff with errors but not report them. Often they're not nice about it - the file will fail a static check for content. Your case of being able to remove one track from a title is actually a bit rare.
macintosh456789
i would like to provide my DVD disc image in order to study the situation i got so far for the author of MakeMKV.Woodstock wrote: Mon Feb 20, 2023 8:02 pm Theory says it could be cleaned up with a disk cleaning. There are a number of drives that can read stuff with errors but not report them. Often they're not nice about it - the file will fail a static check for content. Your case of being able to remove one track from a title is actually a bit rare.
whether to keep region code or to remove region code, both of disc's image are possible for me to provide.
i do not know what the "cleaned up" means. i am so sorry for my poor english.
but what you mean is about cleaning the physical disc, well, it is unnecessary for me to do it...
all three discs i had extracted will always fail to extract the english subtitle.
further, it also includes the brand new one i purchased.
is it about the BD-Drive i am using?
i can also provide the information about the BD-Drive.
Someone else posted a similar error: viewtopic.php?f=8&t=30325
