Lord Szechenyi
#1606 Post by Lord Szechenyi » Thu Feb 16, 2023 10:23 am
Mr_Orange wrote: Thu Feb 16, 2023 2:13 am Does it say MT1959 on it? That is more critical than the date of manufacture although I suspect Feb 2020 is fine.
Firmware version doesn't matter as you should flash it to WH16NS60 1.02MK.
Where does it say that?
(btw these are the pics from the listing)
#1607 Post by Coopervid » Thu Feb 16, 2023 10:30 am
Lord Szechenyi wrote: Wed Feb 15, 2023 8:21 pm I'm about to buy an LG BH16NS55, according to the guide, if it's only version 1.04 it's good, but the specific model I found says it was manufactured in February 2020, does this mean it won't work?
Also, I'm an absolute noob at this, and I'm still confused on what the step-by-step is.
Post your Makemkv info. The information for the chip should be MT1959. Most likely it is and you are good to flash it.
daave
#1608 Post by daave » Thu Feb 16, 2023 4:16 pm
Hello everyone, I would like to buy a UHD official drive for ripping and playing 4K bluray and the normal ones.
Which are the UHD official internal or external drive that I can get? Is there an updated list? I am from Italy.
Thank you in advance.
#1609 Post by Coopervid » Thu Feb 16, 2023 5:35 pm
daave wrote: Thu Feb 16, 2023 4:16 pm Hello everyone, I would like to buy a UHD official drive for ripping and playing 4K bluray and the normal ones.
Page 1 of this thread.
daave
#1610 Post by daave » Thu Feb 16, 2023 5:40 pm
Thank you Coopervid. So that one is the latest list, is it?
#1611 Post by Coopervid » Thu Feb 16, 2023 5:53 pm
Lord Szechenyi wrote: Thu Feb 16, 2023 10:23 am
Did you see my reply under your post? Anyway - you should be fine to flash.
Go to page one. See Unlocked flashers and download the first two links. Flash either LG BH16NS55 1.03 from the OLD directory or cross-flash to BH16NS60 1.02 from the HL-DT-ST directory. You need the SDFToolFlasher. Older flashers won't work.
daave
#1612 Post by daave » Thu Feb 16, 2023 6:13 pm
I have another question, if I buy a UHD friendly drive, I can't play the movie on my laptop but I can rip it and then play, right?
If I buy a UHD official drive, can I play the movie on whatever laptop?
Because I saw that the CPU must support SGX in order to play the movie directly without ripping. (SGX is supported only by Intel cpus (10th gen or earlier)
Dakinathon
#1613 Post by Dakinathon » Thu Feb 16, 2023 8:04 pm
A month ago ( January 2023) I bought the https://www.amazon.com/MthsTec-Powerful ... B09QC1VYNZ. It contains within the enclosure the latest and greatest Blu-Ray LG WH16NS48 drive. When it works (about 80% of the time, these are older Blu-Ray disks) it is amazingly fast at 16X it backs up a 2 hour Blu-Ray movie in about 20 minutes. The other 20% of the time with newer videos it will error out in literally 3 to 4 sec. Disappointing to say the least. The error(s) = OS error and Scsi error are shown below. Since this is the case, can I take it for granted that MakeMKV needs to be updated to be able to bypass (New?) security measures.
At this time there is no firmware available for this drive, it is that new and I have come to believe that MakeMKV is causing the problem. I'm not an expert, I'm searching and struggling to find a way to make this work.
Any help or insights that anyone can offer would be gratefully accepted.
Thanks in advance for reading this request.
MakeMKV v1.17.3 win(x64-release) started
Using Java runtime from C:\Program Files\Java\jre1.8.0_351\bin\java.exe
Title #00631.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00299.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00803.mpls was added as title #3
Title #00307.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00189.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00681.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00431.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00682.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00688.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00689.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00683.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00684.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00685.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00686.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00687.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00690.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
Title 00853.mpls is equal to title 00803.mpls and was skipped
Title #00002.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 4 titles into directory E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '219936768'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '219936768'
Failed to save title 0 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0101_t00.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00801.m2ts' at offset '0'
Failed to save title 1 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0102_t01.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '0'
Failed to save title 2 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0103_t02.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '0'
Failed to save title 3 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0104_t03.mkv
0 titles saved, 4 failed
#1614 Post by Billycar11 » Thu Feb 16, 2023 8:15 pm
Dakinathon wrote: Thu Feb 16, 2023 8:04 pm A month ago ( January 2023) I bought the https://www.amazon.com/MthsTec-Powerful ... B09QC1VYNZ. It contains within the enclosure the latest and greatest Blu-Ray LG WH16NS48 drive. When it works (about 80% of the time, these are older Blu-Ray disks) it is amazingly fast at 16X it backs up a 2 hour Blu-Ray movie in about 20 minutes. The other 20% of the time with newer videos it will error out in literally 3 to 4 sec. Disappointing to say the least. The error(s) = OS error and Scsi error are shown below. Since this is the case, can I take it for granted that MakeMKV needs to be updated to be able to bypass (New?) security measures.
Nah a firmware flash won't fix that it's either a disc issue or drive issue.
The usual steps are
Clean the disc
Replace the disc
Clean the drive
Replace the drive with a Wp/bp50nb40 BU40N ect... Or get a flashed and tested drive from one of the sellers
#1615 Post by Coopervid » Thu Feb 16, 2023 8:41 pm
daave wrote: Thu Feb 16, 2023 6:13 pm I have another question, if I buy a UHD friendly drive, I can't play the movie on my laptop but I can rip it and then play, right?
Forget SGX. Rip the movie with either an official or friendly drive. Play with VLC or MPC.
daave
#1616 Post by daave » Thu Feb 16, 2023 8:51 pm
Thank you Cooper. I have a laptop and I am buying a LG WH16NS40, what kind of adapter I need in order to use it?
#1617 Post by Coopervid » Thu Feb 16, 2023 9:21 pm
See page 1 for enclosure and adapter options.
#1618 Post by Billycar11 » Thu Feb 16, 2023 10:15 pm
Coopervid wrote: Thu Feb 16, 2023 8:41 pm Forget SGX. Rip the movie with either an official or friendly drive. Play with VLC or MPC.
man i wish people would forget SGX everyday i get an email telling me they need SGX to rip/play UHDS.
the implementation was so flawed no intel boards had native HDMI 2.0 from 7th-10th gen so that means no HDR
there were boards that used the cpus DisplayPort link to convert to HDMI 2.0 but then you miss out on lossless audio and bit streaming it to your AVR.
and you have to have a specific version of windows 10 for the stupid powerdvd sgx test to pass all new version of 10 it would fail even if sgx was working in the intel test app
#1619 Post by SamuriHL » Fri Feb 17, 2023 12:21 pm
There are some good things that came out of sgx. Because it's so flawed a group managed to extract powerdvd's host cert and use it to play uhds in Linux in vlc. Lol
daave
#1620 Post by daave » Fri Feb 17, 2023 8:36 pm
LG WH16NS40 vs Asus BW-16D1HT which one is better? And why?
