Terrifier stuck scanning cd rom!
BobbyP
Post by BobbyP »
I have an -ASUS BW-16D1HT- and when I try and load Terrifier on Blu-ray it wont read the disc and just says scanning cd rom until it times out and says no disc.
Re: Terrifier stuck scanning cd rom!
Well, your description is trying to put a Bluray into a CD drive, which isn't going to work.
The Asus is actually a Bluray drive, so it will normally work, unless you tried to put a UHD disk in it; UHD disks require that the Asus be reprogrammed to allow UHD format to be read.
Have you done that yet?
BobbyP
Post by BobbyP »
Yes, I bought it from someone who sells the drives and I've already ripped plenty of 4K's, 3D's, Blu-rays, and DVD's. I just keep getting this problem with this disc. I have other issues with the drive but I'll save that for another topic and keep this related to Terrifier.
Have you tried gently cleaning the disc?
