Best USB adapter for using LG BP60NB10
DC-2187
Post by DC-2187 »
I have to use a USB adapter because on my windows laptop I have only one usb-a port and three type c ports but i was using a usb type c adapter and it started giving me some issues with opening 4k discs after a few successful rips. i switched up the usb adapter and am now on my Mac Mini M2 and it is working without any issues.
so my question is if there is a good usb dongle that i can pair up with my drive. I dont know if this issue is common or not.
Re: Best USB adapter for using LG BP60NB10
DC-2187 wrote: Wed Feb 15, 2023 3:19 am I have to use a USB adapter because on my windows laptop I have only one usb-a port and three type c ports but i was using a usb type c adapter and it started giving me some issues with opening 4k discs after a few successful rips. i switched up the usb adapter and am now on my Mac Mini M2 and it is working without any issues.
Get yourself a powered USB hub. A few extra USB ports won't go astray!
DC-2187
Post by DC-2187 »
MartyMcNuts wrote: Wed Feb 15, 2023 4:19 am
i thought perhaps this could be an issue. thank you for the tip
you could also get this https://smile.amazon.com/dp/B00UUBRX0Y? ... ct_details
but the powered hub is the much better idea these drives are power hungry alot of laptops have trouble powering them
DC-2187
Post by DC-2187 »
Billycar11 wrote: Wed Feb 15, 2023 6:12 am you could also get this https://smile.amazon.com/dp/B00UUBRX0Y? ... ct_details
i ended up getting a powered hub. this will be just be when i'm using my laptop. i imagine once i get my desktop PC rebuilt that this wouldn't be necessary to use?
DC-2187 wrote: Wed Feb 15, 2023 7:35 pm
its almost luck some highend motherboards supply enough power some dont i have had good luck with Asus and Gigabyte
i have even seen the m1 macs sometimes supply enough power other ones don't why idk
