MacOS Ventura No Longer Reading Disc's
deperkins
#1 Post by deperkins » Sat Jan 28, 2023 3:26 am
Long story short, my iMac stopped reading dvd and Blu-ray Discs in my Pioneer BDR-XD05B external drive. Last weekend, I completely wiped my iMac and reloaded MacOS Ventura and started from scratch. Once I was back up and running, I put a Blu-ray Disc in and it was working as it should. I ripped the disc that was in there and eventually reinstalled all of my software and things are looking good. That brings me to today. I put a disc in and sure enough, the iMac is back doing what it was doing a week ago. I put the disc in, the disc spins but the computer never reads the disc. In System Information, I click on USB under Hardware and my Pioneer drive shows up that it's setting it. But when I go to Disc Burning, the system says that no disc burning device was found. Has anyone run into something similar to this and found an easier fix than wiping the computer and starting from scratch????
Re: MacOS Ventura No Longer Reading Disc's
#2 Post by dcoke22 » Sat Jan 28, 2023 6:35 pm
I'm a little confused. Are you saying that your optical drive doesn't register any disc in the drive? Or does it not register a single, particular disc in the drive?
Does your drive work with a CD or DVD (which uses a different laser than a blu-ray)?
deperkins
#3 Post by deperkins » Sat Jan 28, 2023 7:14 pm
Doesn’t register any disc in the drive. The disc spins but that’s it. It doesn’t matter if it’s a dvd disc or a Blu-ray Disc.
deperkins
#4 Post by deperkins » Sat Jan 28, 2023 7:52 pm
Bought an LG drive to replace my Pioneer drive. Plugged in and…knock on wood…so far, so good!
Damfino
#5 Post by Damfino » Mon Jan 30, 2023 10:51 pm
Today I've experienced the same issue. MakeMKV on my 2018 Mac Mini running MacOS Ventura suddenly stopped seeing my Pioneer BDR-XD07UHD drive, but the Mini sees it in System Information. I also have an LG drive attached and MakeMKV sees that one with no issues.
I then attached it to an older 2011 Mac Mini running an older MakeMKV and older MacOS and it is seen with no issue.
I have not had this issue prior to today, and have ripped a few blu's with this drive under Ventura, but wondering if this is due to the recent 13.2 update?
Anyone else experiencing this issue?
Damfino
#6 Post by Damfino » Mon Jan 30, 2023 10:56 pm
Answering my own question. it is an issue with MacOS Ventura 13.2. From Pioneer's website:
Important notice: We have confirmed that our optical drives are not recognized by macOS Ventura 13.2 released by Apple on January 23, 2023. We are currently investigating this symptom. We would like to ask our customers who are using our optical drives to refrain from updating to macOS Ventura 13.2.
deperkins
#7 Post by deperkins » Mon Jan 30, 2023 11:08 pm
I was having issues with my drive and it had stopped working prior to the latest update, which led me to replace it.
rkhollister
#8 Post by rkhollister » Sat Feb 04, 2023 4:21 pm
As a test, I updated my secondary Mac (13" M1 MBP) to 13.2 and tried my Pioneer BDP-S13UBK in an external USB enclosure - works normally. I suspect the issue is with the USB interface in the Pioneer portable drives and not the actual drive firmware.
floatinjoe
#9 Post by floatinjoe » Mon Feb 06, 2023 4:41 pm
I've been having similar issues with a Buffalo drive. It recognizes that a disc is in the drive, but it took forever for it to do that. Also, it takes MakeMKV over an hour to open a BD.
I am also running two UHD drives and though they find the discs and are able to rip them, I am receiving the error "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive". The discs in question were The Hobbit 6-disc set and Hellboy & Hellboy 2.
I've never had that issue before the upgrade of the MacOS.
Cuddy2977
#10 Post by Cuddy2977 » Tue Feb 14, 2023 6:30 am
I’m having the same issue: I have an Archgon-branded* UHD blu-ray drive — that was showing up in the System Profiler — until I updated to Ventura 13.2.
And now seems to be non-functional: except, of course, it works perfectly well in my aging MacPro running Lion
viewtopic.php?f=16&t=30267&p=132431#p132431
Update: I’ve JUST updated to macOS 13.2.1. That seems to have fixed the issue
* It’s a Pioneer UD04, in an Archgon case
rkhollister
#11 Post by rkhollister » Tue Feb 14, 2023 10:48 am
Apple just released 13.2.1 and I saw at least one comment on MacRumors that their Pioneer UHD drive is working again.
dpunder
#12 Post by dpunder » Wed Feb 15, 2023 6:13 am
Mine is working now.
Cuddy2977
#13 Post by Cuddy2977 » Wed Feb 15, 2023 8:49 am
I had the same issue: my Pioneer drive didn’t show up under macOS 13.2: but does, under macOS 13.2.1
floatinjoe
#14 Post by floatinjoe » Wed Feb 15, 2023 5:31 pm
Everything seems to be working correctly again for me also.
Zulith
#15 Post by Zulith » Tue Feb 21, 2023 7:15 pm
Glad they fixed this in the very next patch, what a blunder. Just as I am purchasing new hardware too... lovely timing.
