I am having a failure on this disc. By all indications, looks brand new. It is a Netflix rental, not store bought. First BD I have problems with in a while but is a newer release. I've ripped 100's with makemkv, so I have experience and followed the typical procedures. I will order a replacement just in case, but again, the disc looks absolutely pristine.
Attached is the log file with debug enabled.
Retries set to 10.
Thank you,
MrRocco
No Time to Die (2021) rip failure
MrRocco
- MakeMKV_log.txt
- (48.65 KiB) Downloaded 341 times
Re: No Time to Die (2021) rip failure
Your ASUS BW-16D1HT drive was struggling to read the disc.
It has been my experience that some drives just don't like some discs. I have 3 different drives, including an ASUS like yours. When my 'main' drive fails to read a disc, I try the disc in a different drive and often it works fine.
002023:0000 Encountered 48 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=6 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
