Misery UHD DV problem
Alldu
#1 Post by Alldu » Sun Feb 12, 2023 6:14 pm
I just ripped the Misery DV UHD with the LG BP50NB40 and somehow the DV isn't working. I play .m2ts files via Sony X700, and never had a problem with playing ripped double-layerd DV files. But this one, even though it has tha DV layer intact, won't trigger the DV on my TV - just plays it in HDR10.
Funny thing is, when I scan the ripped disc with BDInfo, it shows the DV layer:
Codec                   Bitrate             Description
MPEG-H HEVC Video       0 kbps              2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020
* MPEG-H HEVC Video     0 kbps              1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / Dolby Vision / BT.2020
But when I check the main .m2ts file with MediaInfo, it shows 2 HDR10 layers, and not one HDR10 and the onther one the DV layer - like it's with my other DV .m2ts files:
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 h 47 min
Maximum Content Light Level              : 7130 cd/m2
Maximum Frame-Average Light Level        : 545 cd/m2
Video #2
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Does anybody know what the problem is, and how do I fix it?
