hell001
#7966 Post by hell001 » Thu Feb 09, 2023 1:54 am
jayper wrote:
Mon Feb 06, 2023 3:01 am
hell001 wrote:
Sat Feb 04, 2023 9:15 pm
johnjon94 wrote:
Thu May 12, 2022 8:48 pm
I meant in regards to movies that don't have IMAX DV WEB-DL releases but have an IMAX HDR WEB-DL, like Spider-Man Far From Home.
Also wondering about this same film, as well has No Way Home. I've seen a few IMAX hybrid releases where the uploader credits the DV layer from a non-IMAX release, and am unsure how this is possible. Can non-IMAX Dolby Vision sources create legit IMAX hybrids? To my knowledge neither FFH nor NWH have IMAX DV releases.
(Note: I am not talking about generating it yourself with Davinci Resolve or some other method.)
I might be wrong, so an actual expert should weigh in, but to my knowledge it is possible to extract an RPU from any DV release. The resolution does not have to match the HDR10 base layer file's resolution.
I’ve heard similar, where you can use say a 1080p DV layer and inject it into a 2160p HDR file. But in those cases the aspect ratio is the same. I wasn’t sure if this also applied to IMAX, specifically with the IMAX release having extra content on the top and bottom. Does the non IMAX DV layer know how to handle that considering its source file doesn’t have that? And produce the same result as if it was coming from an IMAX DV layer?
johnjon94
#7967 Post by johnjon94 » Thu Feb 09, 2023 3:47 am
Unfortunately it's not possible. The DV metadata from a non-IMAX source won't have the necessary information for the extended aspect ratios in the the IMAX scenes.
johnjon94
#7968 Post by johnjon94 » Thu Feb 09, 2023 3:48 am
Unfortunately it's not possible. The DV metadata from a non-IMAX source won't have the necessary information for the expanded aspect ratios in the the IMAX scenes.
staknhalo
#7969 Post by staknhalo » Thu Feb 09, 2023 6:04 pm
On Bravia Core they do
edit: FFH HDR10 IMAX NWH DV8 IMAX
jorgen
#7970 Post by jorgen » Fri Feb 10, 2023 3:42 pm
The best way to play FEL titles is using a physical player (for instance Oppo) with M2TS/TS or BDMV/ISO files. When you create a mkv with Dolby Vision from a UHD disc, is it possible to reverse the process and create a Blu-ray structure from a mkv file and not lose any Dolby Vision information?
Converting can be done with https://github.com/justdan96/tsMuxer
Skinny Pete
#7971 Post by Skinny Pete » Sat Feb 11, 2023 9:53 am
How to switch from Dolby Vision profile 8 to 5
I have this file that has: HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible. I just want to have a file that can be played properly on my TV. A file with: HDR: Dolby Vision, version 1.0, dvhe.05.06, Bl+RPU is reproduced correctly, so I think the first is DV profile 8, the second profile 5. How do I go from 8 to 5 in mp4? Maybe I am doing it wrong and they are not the right profiles, you tell me what I should do.
yossSP
#7972 Post by yossSP » Sat Feb 11, 2023 7:09 pm
RESET_9999 wrote:
Wed Jan 25, 2023 10:46 pm
yossSP wrote:
Wed Jan 25, 2023 10:39 pm
Hi all, I'll launch a question to @RESET_9999 and every other member of this forum.
There's a guy in other forum of my country where I'm in who claims that the FireTV Stick 4K (2018 version) can now playback Dolby Vision FEL titles.
As far as I know there's no FireTV that could playback FEL files using the EL layer. From what I have guessed and taking into account that the guy is basing his claim on viewings with naked eye, this device is playing FEL titles as MEL (without using EL layer), what already has a great quality as is.
Could anybody confirm or deny this statement?
He's probably talking about quietvoid's new kodi build that can play P7 as P8. Read just a couple comments above.
Thanks for your answer, but I think he's playing directly with Plex.
He says that before, when he tried to play with Firestick FEL titles could only get a black screen.
yossSP
#7973 Post by yossSP » Sat Feb 11, 2023 7:14 pm
quietvoid wrote:
Thu Jan 26, 2023 1:38 pm
My 2018 4K stick hasn't been updated in years but it never could play FEL, blank screen.
The 2021 4K Max behaves the same, with latest firmware.
Thanks for your answer @quietvoid, this guy says that before, when he tried to play with Firestick FEL titles could only get a black screen, as you confirmed, but now It could play FEL titles with the TV Dolby Vision Logo enabled.
As I said before I think this device is playing FEL titles as MEL (without using EL layer) but... could It be a good time to update your ancient 2018 Firestick and give it a try? ;)
quietvoid
#7974 Post by quietvoid » Sat Feb 11, 2023 7:26 pm
I'm not updating it, no.
yossSP
#7975 Post by yossSP » Sat Feb 11, 2023 8:00 pm
Ok, of course, but i'm intrigued why are you so sure and categorical. It's because new firmwares are worst in certain aspects?
quietvoid
#7976 Post by quietvoid » Sat Feb 11, 2023 8:10 pm
In the past I've had issues with stutters caused by not having enough free RAM.
The default launcher seems to use more memory, and I still have a custom leaner launcher installed.
I don't have any issue on the 2021 version.
Anyways, the real reason is that I'm keeping it old just to test if behaviour changes in Dolby Vision playback are caused by the TV or device.
Knowing that the device isn't getting updated, I know the TV updates make a difference.
Nowadays I have no more use for the 2018 stick, as the 2021 is better in every way as long as I use Kodi.
yossSP
#7977 Post by yossSP » Sat Feb 11, 2023 11:45 pm
Perfectly clear, I understand.
Therefore, we could assure that if the 2021 4K Max with latest firmware doesn't support FEL DV, the older 2018 shouldn't do it.
Thanks again.
Big-rome
#7978 Post by Big-rome » Sun Feb 12, 2023 5:19 pm
What about kodi as launcher on your android builds?
https://forum.kodi.tv/showthread.php?tid=351513
quietvoid
#7979 Post by quietvoid » Sun Feb 12, 2023 7:49 pm
I'm not interested.
Big-rome
#7980 Post by Big-rome » Sun Feb 12, 2023 11:05 pm
I'm not interested.
ok
