Fatal error occurred, program will now exit - 1.17.3
Kelly
Re: Fatal error occurred, program will now exit - 1.17.3
#1 Post by Kelly » Fri Feb 10, 2023 4:48 pm
I have the same Problem with HD DVDs and I cant go back to an older version
#2 Post by Woodstock » Wed Feb 15, 2023 2:37 am
There have been other reports of problems with HD DVDs since 1.17 came out. Possibly earlier versions.
https://makemkv.com/download/old/ is where you can find old versions of MakeMKV.
#3 Post by dcoke22 » Mon Feb 27, 2023 3:52 pm
If you have a paid-for license you can use older versions of MakeMKV.
