Fast and Furious Blu Ray
buzzlightyear
Post by buzzlightyear »
whenever I load the disc always gives me an error message and ends up saying failed to open disc. Disc has been cleaned and was taken brand new from package. here is the log that it spit out. Disc is a UHD on a flashed BU40N Archgon on Firmware 1.03 it does play fine in blu ray player with no skipping. Is it possible the drive (BU40N) is too picky?
MakeMKV v1.17.3 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3L4T85312d" opened in OS access mode.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3L4T85312' at offset '24742723584'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3L4T85312' at offset '24742787072'
udf: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3L4T85312' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3L4T85312' at offset '32768'
DEBUG: Code 101000192 at *+wdd`UWxCo["#nK5e:121263429
DEBUG: Code 101000192 at *+wdd`UWxCo["#nK5e:121262302
DEBUG: Code 0 at r\E1K7%]j:;Hg=bq)hr:213129777
