Replacement cable for LG BP50NB40
Genesys10101
#1 Post by Genesys10101 » Fri Feb 10, 2023 4:41 am
Are there any Micro USB -> USB-C cables that can be used with the LG BP50NB40 that provide both data transfer and power?
I've got the original Micro USB -> dual USB-A... but I no longer have machines with dual USB-A ports, and even so, I'd like to reduce the number of ports used to 1.
Re: Replacement cable for LG BP50NB40
#2 Post by Billycar11 » Fri Feb 10, 2023 5:36 pm
You can just use the main USB cable and it will work if your USB ports provide enough power but any standard usb a to micro b 2.0 cable will work
mlindstrom
#3 Post by mlindstrom » Thu Dec 19, 2024 5:41 am
I can confirm a standard USB-C to Micro B cable worked for me.
#4 Post by MartyMcNuts » Thu Dec 19, 2024 7:15 am
Genesys10101 wrote: Fri Feb 10, 2023 4:41 am Are there any Micro USB -> USB-C cables that can be used with the LG BP50NB40 that provide both data transfer and power?
If you have a USB-C port, get a micro b to USB-C cable. No need to be concerned at all about the drive getting enough power.
mlindstrom
#5 Post by mlindstrom » Thu Dec 19, 2024 12:20 pm
Whoops I totally meant USB-C, not USB-A. Edited my response above.
