Backup Failed
radishhorse
Backup Failed
Post by radishhorse »
I'm trying to make a backup of the Rocko's Modern Life complete series DVD set. At the very end of the process it'll just say "Backup Failed". Here is the output from the log:
005072:0000 Backing up disc into folder "file:///Users/zzzzzz/Movies/backup/ROCKO'S MODERN LIFE S1 D1.iso"
DEBUG: Code 1 at ;Kzuk8u<J?hK_"7G[:121263199
DEBUG: Code 3 at ;Kzuk8u<J?hK_"7G[:121263199
DEBUG: Code 5 at ;Kzuk8u<J?hK_"7G[:121263199
Launching /Applications/MakeMKV.app/Contents/MacOS/mmgplsrv
DEBUG: Code 0 at i0mr+TQ\,u~3dru]&>";:29396460
003032:0000 Region setting of drive ASUS:BW-16D1X-U does not match the region of currently inserted disc, trying to work around...
DEBUG: Code 0 at cg=(xD(3US1)OP(7':213130306
DEBUG: Code 0 at cg=(xD(3US1)OP(7':121264878
001003:0020 DEBUG: Code 101019395 at pmp)STcczo*'LGHH:121271617
001003:0020 DEBUG: Code 101019395 at *P_=i(6 2Zz:Fuh(:213130559
001003:0020 DEBUG: Code 5 at f5GH"-)Pa/~"-:29395770
001003:0020 DEBUG: Code 0 at %,mXrBO;Aq;"g'7La/r|:121266097
001003:0020 DEBUG: Code 233 at ZRZ1M4Z6pyqKEBrdpBYqW+Ns:0
005069:0080 Backup failed
005080:0204 Backup failed.
This is my drive and disc info:
OS device name: /dev/rdisk3
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: xxxxxxx
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Disc Information
Label: ROCKO'S MODERN LIFE S1 D1
Timestamp: 2018-09-24 14:18:17
Protection: CSS/CPPM
Data capacity: 7.36 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
I've tried multiple discs in the set and the same thing happens. Haven't had issues with other TV shows. Any help would be greatly appreciated!
Re: Backup Failed
That line from your log suggests your DVD is from a different region than your drive is set to. The LibreDrive Information section says your drive isn't flashed to support LibreDrive, although I'm pretty sure it can be.
What is LibreDrive?
I think if you're drive was flashed to support LibreDrive, it would be able to ignore the region encoding on the DVDs (and blu-rays).
The ever useful Ultimate UHD Drives Flashing Guide
radishhorse
Re: Backup Failed
Weird since I get the warning about the region with other DVD's and am still able to backup successfully. Also, if what I'm trying to rip is not UHD do I need LibreDrive?
Re: Backup Failed
radishhorse wrote: Thu Feb 09, 2023 8:56 pm Weird since I get the warning about the region with other DVD's and am still able to backup successfully. Also, if what I'm trying to rip is not UHD do I need LibreDrive?
Generally speaking no. MakeMKV can rip DVDs and blu-rays without LibreDrive. Doing it for a different region, however, and the answer changes to maybe.
