converting BDMV folder to 1 .mkv file
So I downloaded this HD DEMO bluray disk and it is in the natural bluray file structure with the main folder being BDMV. I pointed makeMKV to the index.bdv and i went about it's business converting it over to .mkv. only problem is, it made multiple .mkv files instead of 1 large one with a menu.
setarip_old
Re: converting BDMV folder to 1 .mkv file
What you've described indicates that your demo disc is comprised of several separate titles.
1) MakeMKV makes converts EACH title to an .MKV.
2) Presently (regardless of program used) Matroska/MKV does not support the inclusion of active menus
