Opening ISO files from windows explorer
phunqe
#1 Post by phunqe » Fri May 06, 2011 11:05 am
I want to be able to double click an ISO file in windows explorer and have it load into MakeMKV.
I have associated .iso files with makemkv.exe but it only opens an empty MakeMKV without loading the file.
Please advice.
Thank you.
Re: Opening ISO files from windows explorer
#2 Post by mike admin » Fri May 06, 2011 1:29 pm
It's not possible now. Thanks for suggestion, will try to add in the next version.
phunqe
#3 Post by phunqe » Fri May 06, 2011 6:03 pm
Thank you for the quick reply. I look forward to seeing it implemented :)
Cheers.
