Donnie Darko Theatrical Disc Error
annie31
#1 Post by annie31 » Sun Jan 08, 2023 11:43 pm
I bought the standard arrow 4k edition of donnie darko and the the theatrical cut disc won't read at all. The director's cut works fine. Using my WH16NS60 with patched firmware, all my other Blu-rays and 4k UHD Blu-rays load up fine in VLC. Inserting the theatrical cut, the drive makes some heavy loading noises while trying to read it but after a while it seems to give up and says "No disc inserted". Loads up fine on the living room DP-UB150. Debug file only says "DEBUG: Code 3 at 6CF;l<+$x9]D6No(y!wmrg:29395310"
I thought it might be a bad disc, because I found out that the theatrical disc in the collector's edition had a bad batch, but arrow said the standard edition should be unaffected as it was made after they fixed the issue.
If anyone else has this disc and could tell me if their disc gets read it would be very helpful.
demon
Re: Donnie Darko Theatrical Disc Error
#2 Post by demon » Mon Jan 09, 2023 2:08 am
I dumped mine out some time ago (when I received it, right about the time it was released), and it worked just fine for me. Your WH16NS60 might be starting to get picky about discs - mine did that before it stopped reading all discs (I now have 2 BU40N drives, which work fine).
lukeyrada
#3 Post by lukeyrada » Wed Feb 08, 2023 8:09 pm
I also had a problem ripping that Disc. The Theatrical Cut was perfectly fine but the Directors Cut took around 3 hours. Thankfully the rip was successful and it works fine. Usually a rip takes around 1 hour. Initially the Disc wasn't reading properly. I use a Pioneer BDR-XD07TUHD with a 2021 M1 Macbook Pro running the latest Ventura OS. That drive required no updates and worked straight out of the box.
ben_uk
#4 Post by ben_uk » Tue Apr 02, 2024 4:47 pm
Forgive the bump for this.
I recently ripped this and the theatrical version spat out all this;
AV sync issue in stream 0 at 0:00:06.506 : video frame timecode differs by +41.7ms
AV sync issue in stream 0 at 0:00:06.610 : video frame timecode differs by -62.57ms
AV sync issue in stream 0 at 0:00:06.610 : secondary stream video frame timecode differs by +20.851ms
AV sync issue in stream 0 at 0:00:06.610 : secondary stream video frame timecode differs by -62.57ms
AV sync issue in stream 0 at 0:00:06.652 : video frame timecode differs by +62.554ms
AV sync issue in stream 0 at 0:00:06.694 : video frame timecode differs by +20.845ms
AV sync issue in stream 0 at 0:00:06.694 : secondary stream video frame timecode differs by +271.101ms
AV sync issue in stream 0 at 0:00:06.694 : secondary stream video frame timecode differs by +187.679ms
AV sync issue in stream 0 at 0:00:06.735 : video frame timecode differs by +20.848ms
AV sync issue in stream 0 at 0:00:06.756 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:00:06.756 : secondary stream video frame timecode differs by +41.705ms
AV sync issue in stream 0 at 0:00:06.756 : secondary stream video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:00:06.756 : secondary stream video frame timecode differs by -83.416ms
AV sync issue in stream 0 at 0:00:06.798 : video frame timecode differs by +83.408ms
AV sync issue in stream 0 at 0:00:06.840 : video frame timecode differs by +41.7ms
AV sync issue in stream 0 at 0:00:06.881 : video frame timecode differs by +41.702ms
AV sync issue in stream 0 at 0:00:06.902 : video frame timecode differs by -20.862ms
AV sync issue in stream 0 at 0:00:06.944 : video frame timecode differs by +104.262ms
AV sync issue in stream 0 at 0:00:06.986 : video frame timecode differs by +62.554ms
AV sync issue in stream 0 at 0:00:06.986 : secondary stream video frame timecode differs by +20.854ms
AV sync issue in stream 0 at 0:00:06.986 : secondary stream video frame timecode differs by +104.265ms
AV sync issue in stream 0 at 0:00:07.027 : video frame timecode differs by +62.556ms
AV sync issue in stream 0 at 0:00:07.048 : secondary stream video frame timecode differs by -208.541ms
AV sync issue in stream 0 at 0:00:07.048 : secondary stream video frame timecode differs by -125.13ms
AV sync issue in stream 0 at 0:00:07.048 : secondary stream video frame timecode differs by +83.413ms
AV sync issue in stream 0 at 0:00:07.090 : video frame timecode differs by +125.116ms
AV sync issue in stream 0 at 0:00:07.132 : video frame timecode differs by +83.408ms
AV sync issue in stream 0 at 0:00:07.257 : video frame timecode differs by +83.416ms
AV sync issue in stream 0 at 0:00:07.298 : video frame timecode differs by +41.708ms
AV sync issue in stream 0 at 0:00:07.340 : video frame timecode differs by +41.7ms
AV sync issue in stream 0 at 0:00:07.340 : secondary stream video frame timecode differs by -125.133ms
AV sync issue in stream 0 at 0:00:07.340 : secondary stream video frame timecode differs by -166.833ms
AV sync issue in stream 0 at 0:00:07.340 : secondary stream video frame timecode differs by +83.411ms
AV sync issue in stream 0 at 0:00:07.361 : video frame timecode differs by -20.854ms
AV sync issue in stream 0 at 0:00:07.361 : secondary stream video frame timecode differs by -104.276ms
AV sync issue in stream 0 at 0:00:07.465 : secondary stream video frame timecode differs by -166.836ms
AV sync issue in stream 0 at 0:00:07.465 : secondary stream video frame timecode differs by -83.425ms
AV sync issue in stream 0 at 0:00:07.507 : video frame timecode differs by +41.7ms
AV sync issue in stream 0 at 0:00:07.611 : video frame timecode differs by -62.57ms
AV sync issue in stream 0 at 0:00:07.611 : secondary stream video frame timecode differs by +20.851ms
AV sync issue in stream 0 at 0:00:07.611 : too many video frames with invalid timecodes, future messages will be suppressed
AV sync issue in stream 0 at 1:53:10.617 : video stream has 241947 frames with invalid timecodes
AV sync issue in stream 6 at 0:00:00 : Forced subtitles track #6 turned out to be empty and was removed from output file
AV sync issue in stream 1,2 at 0:16:52.202 with duration of 76.166ms : audio gap - 2.38 missing frame(s)
AV sync issue in stream 1,2 at 0:26:20.680 with duration of 68.583ms : audio gap - 2.143 missing frame(s)
AV synchronization issues were found in file 'E:/DDarko/DONNIE DARKO (Theatrical Cut) - 4K UHD_t27.mkv' (title #28)
What actually does all this mean?
