ripping impossible
Guytoon
ripping impossible
Post by Guytoon » Tue Feb 07, 2023 5:28 pm
Bonjour,
Impossible de ripper mon blu-ray UHD "The Revenant"; voici le message :
Capture d’écran 2023-02-07 à 18.14.40.png (141.86 KiB) Viewed 6683 times
J'ai entendu parler de patch, que dois-je faire?
Merci
Good morning,
Can't rip my UHD blu-ray "The Revenant"; here is the message:
I heard about patch, what should I do?
THANKS
Re: ripping impossible
Post by d00zah » Tue Feb 07, 2023 6:13 pm
Guytoon wrote: Tue Feb 07, 2023 5:28 pm Good morning,
THANKS
Flashing firmware on a Mac for LibreDrive
BU40N on any Firmware directly to > BU40N 1.03MK
Ultimate UHD Drives Flashing Guide Updated 2023
Guytoon
Post by Guytoon » Tue Feb 07, 2023 6:24 pm
My reader is a Archon UHD...
Post by d00zah » Tue Feb 07, 2023 7:19 pm
Guytoon wrote: Tue Feb 07, 2023 6:24 pm My reader is a Archon UHD...
Capture d’écran 2023-02-07 à 18.14.40 (Small).png (77.34 KiB) Viewed 6671 times
FW v1.02 is on the 'encrypted' list, so use the command line example containing 'enc'.
