DVD was skipped due to navigation error
joseph_maclure
Post by joseph_maclure » Tue Feb 07, 2023 4:23 pm
Trying to rip a disc and it is giving me the above error.
It was skipping when trying to rip the disc, then even after trying Manual mode it doesn't work either... Tired a backup and it failed also, this is the only disc I've had issues manual mode worked for another disc that was skipping some titles too.
Any suggestions?
Re: DVD was skipped due to navigation error
Post by dcoke22 » Tue Feb 07, 2023 7:45 pm
I don't think making a backup should be dependent on being able to navigate the structure of the disc. What error did you get when you tried to make a backup? Have you tried gently cleaning the disc?
clenchdwarf
Post by clenchdwarf » Sat Feb 11, 2023 12:47 am
There are a very few weirdly authored discs that break makemkv. I resorted to ripping one with DVD Decrypter, then converting to mkv somehow.
Ezatoka
Post by Ezatoka » Sat Feb 11, 2023 6:47 pm
Can also try to set a different DVD Opening Mode viewtopic.php?f=7&t=28541
joseph_maclure
Post by joseph_maclure » Mon Feb 13, 2023 10:50 am
Back up error is simply 'Failed to Create a back up'
I'll try the other modes and see does this help otherwise I'll try the decrypter.
If they work I'll post an update, thanks :D
joseph_maclure
Post by joseph_maclure » Thu Mar 02, 2023 5:13 pm
Hi all, just to close this out I believe the issue was just with some strange copyright on these two discs.
I bought used discs from a different region and they ripped fine. Thanks for all the suggestions
