Trying to rip a disc and it is giving me the above error.
It was skipping when trying to rip the disc, then even after trying Manual mode it doesn't work either... Tired a backup and it failed also, this is the only disc I've had issues manual mode worked for another disc that was skipping some titles too.
Any suggestions?
DVD was skipped due to navigation error
joseph_maclure
Re: DVD was skipped due to navigation error
I don't think making a backup should be dependent on being able to navigate the structure of the disc. What error did you get when you tried to make a backup? Have you tried gently cleaning the disc?
clenchdwarf
There are a very few weirdly authored discs that break makemkv. I resorted to ripping one with DVD Decrypter, then converting to mkv somehow.
Ezatoka
Can also try to set a different DVD Opening Mode viewtopic.php?f=7&t=28541
joseph_maclure
Back up error is simply 'Failed to Create a back up'
I'll try the other modes and see does this help otherwise I'll try the decrypter.
If they work I'll post an update, thanks
joseph_maclure
Hi all, just to close this out I believe the issue was just with some strange copyright on these two discs.
I bought used discs from a different region and they ripped fine. Thanks for all the suggestions
