The Giver DVD
Traveler2032
The Giver DVD
#1 Post by Traveler2032 » Mon Feb 06, 2023 3:53 pm
I am new to MakeMKV, so maybe this is a known problem/solution, but I've had a couple of disks error out on me like this. The latest is "The Giver". The error is below. What can I try to resolve it?
Saving 1 titles into directory D:/Video/THE_GIVER
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '3135678464'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '3135678464'
Failed to save title 1 to file D:/Video/THE_GIVER/title_t01.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Re: The Giver DVD
#2 Post by Woodstock » Mon Feb 06, 2023 5:24 pm
It depends upon the cause. Does the offset change for different runs?
The generic problem is that the drive starts moving faster than it has power to, and shuts down. This often happens with USB-powered devices, and is fixed by either keeping the drive from going that fast, or giving it full power (plugging in both USB cables to INDEPENDENTLY POWERED USB ports.
But it can happen on fully-powered devices, too. Rare, and the errors are usually different, in that the drive doesn't shut down.
Traveler2032
Re: The Giver DVD
#3 Post by Traveler2032 » Mon Feb 20, 2023 5:59 pm
Both are USB drives, but I definitely have both drives plugged direct into motherboard Super-speed USB ports which should prevent power problems (750W PSU, both motherboard power cables are plugged in). I've ripped about 300 CDs and this only happened on 3 of them.
I will check if the offset changes. I'm not sure.
