Reworked code version not ready yet?quietvoid wrote: Fri Jan 27, 2023 1:23 amI don't know but it doesn't add up. I tested a version from the day before and it's also crashing with my test files.ragico wrote: Thu Jan 26, 2023 11:55 pm Sorry no. All my P7.ts are from Dovi Fel on purpose. None is from a Mel. And I can assure you that they worked and played perfectly. Unfortunately I did not keep that version.
You're welcome to try it: https://mega.nz/file/pZln1IhT#QlMIyPOhW ... 6LidHO1Xqg
This one is the old org.xbmc.kodiDV package.
I don't have the 2023-01-23 build anymore.
Anyways, I have to rework the code so that it works for all files.
This is just temporary.
