Pioneer BDR-S13UBK Lots of errors
ssmokeyy
Post by ssmokeyy »
So I have checked that my BDR-S13UBK firmware is 1.03. Libra is on. This is all im getting from makemkv when ripping. What step did i miss?
Hash check for /BDMV/STREAM/00045.m2ts : 99.58% corrupt, 0% correct, 99.58% checked.
Hash check failed for file 00053.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00053.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00053.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00053.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00053.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00053.m2ts.
Hash check for /BDMV/STREAM/00053.m2ts : 98.31% corrupt, 0% correct, 98.31% checked.
Hash check failed for file 00061.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00061.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00061.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00061.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00061.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00061.m2ts.
Hash check for /BDMV/STREAM/00061.m2ts : 98.59% corrupt, 0% correct, 98.59% checked.
Hash check failed for file 00010.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00010.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00010.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00010.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00010.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00010.m2ts.
Also at the start it said
rror 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Re: Pioneer BDR-S13UBK Lots of errors
do the usual
clean the disc
replace the disc
clean the drive
replace the drive
ssmokeyy
Post by ssmokeyy »
Brand new drive brand new disk. Could it be something else im doing? So i pulled out my old dell workstation with a lg drive that worked for makemkv and i put this disk in it and it ripped it after 2 hours. But now plex can't see the movie and i can't find a mkv file in the folder at all. The folder size is 62gb's and makemkv said finished with no errors on this pc. Movie is bumblebee. Wonder what that could mean.
ssmokeyy wrote:
Mon Feb 06, 2023 12:28 am
Did you do a folder backup or create a MKV file? If you did a folder backup, there is no mkv file as you backed up the entire disc to a folder structure, just like what is on the disc.
Generally, with those sort of errors, the first thing you should do is clean the disc! It doesn't matter if the disc is brand new and spotless.
ssmokeyy
Post by ssmokeyy »
When I go to make a mkv the errors come into play.
The one I got to work was a backup.
