Oh goddamnit. For some reason I was thinking they did the encryption crap with 1.03. Thanks, guys.
Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
glc650
Can the Archgon with BU40N 1.00 rip as reliably/error free as the Pioneers seem to?MartyMcNuts wrote: Sun Feb 05, 2023 8:27 pmThe Pioneer only works with MakeMKV and AnyDVD software. The Archgon, if flashed with BU40N 1.00 works with all ripping software. The Archgon is a little bit quicker (6x vs 4x). The Pioneer drives are generally a bit quieter.glc650 wrote: Sun Feb 05, 2023 12:10 pm Thinking about picking up a second drive for another PC. Any reason to get a Pioneer BDR-XS07UHD over a Archgon MD-8107S-U3-UHD (besides not having to flash)? Reliability? Performance? Software compatibility?
Yes, I have one and my dad just got one which is what my post about flashing is about. The bu40n is a tank. Very reliable drive.
i mean they did after 1.03 so your right its just that archgon is using the Taiwan version of the drive and the version numbers are different 1.02 tw is basically 1.04 usSamuriHL wrote: Mon Feb 06, 2023 1:49 amOh goddamnit. For some reason I was thinking they did the encryption crap with 1.03. Thanks, guys.
chaos58503
How do I flash this drive using a Mac? I'm lost!!!
you read the first post if you cant follow that then you should have just bought one preflashed and tested
Oh no kidding?? I didn't know that. Jesus they really threw me on this one. I'll deal with his drive Wednesday and get it back to 1.00 like mine. He'll be using his on a new Samsung book3 ultra with an i9 and 4070. Going to be a sweet little setup.Billycar11 wrote:i mean they did after 1.03 so your right its just that archgon is using the Taiwan version of the drive and the version numbers are different 1.02 tw is basically 1.04 usSamuriHL wrote: Mon Feb 06, 2023 1:49 amOh goddamnit. For some reason I was thinking they did the encryption crap with 1.03. Thanks, guys.
Yeah take it from me who's flashed several drives using command line on both windows and now Mac, you will need to read and follow it exactly. And know what you're flashing which I clearly didn't. Lol the instructions in the first post are correct. You list the drives to find its id, then use that to flash, making sure to know if the firmware is on its encrypted or not.
Ralph P.
Greetings,
I wanted to advise of another Pioneer drive that works right from the box. I just added the Pioneer BDR-XD08UMB-S to my set up and it works just fine. At $140 it's great for what it offers. I recommend downloading the Pioneer BD-Drive Utility from their website as it allows customization of the drive's performance.
Thanks as always for all that you guys do!
Best,
Ralph
Best,
Ralph
swkeith
Is there any benefit to the LG WP50NB40 vs BP50NB40 vs BP60NB10? I need to pick one up and wondering if one is better than another after flashing or if they are all essentially the same and just go with the cheapest one. Thanks.
liamtoh1
Did you explore this utility? I did not find any comprehensive documentation regarding various options. I see the explanation at high level but wary of causing long term harm to the drive, by say going to "High Performance Mode". In my case, the "Setting 1" tab is disabled.Ralph P. wrote: Wed Feb 08, 2023 8:32 pm I recommend downloading the Pioneer BD-Drive Utility from their website as it allows customization of the drive's performance.
all the same except the bp60 that can do official playback but otherwise the sameswkeith wrote: Wed Feb 08, 2023 9:26 pm Is there any benefit to the LG WP50NB40 vs BP50NB40 vs BP60NB10? I need to pick one up and wondering if one is better than another after flashing or if they are all essentially the same and just go with the cheapest one. Thanks.
get whatever is cheapest wp50 on amazon is usually $90
best buy some times have the BP50 for $80
Shockingly (LOLOLOL), it worked this time.SamuriHL wrote: Mon Feb 06, 2023 4:04 amOh no kidding?? I didn't know that. Jesus they really threw me on this one. I'll deal with his drive Wednesday and get it back to 1.00 like mine. He'll be using his on a new Samsung book3 ultra with an i9 and 4070. Going to be a sweet little setup.Billycar11 wrote:i mean they did after 1.03 so your right its just that archgon is using the Taiwan version of the drive and the version numbers are different 1.02 tw is basically 1.04 usSamuriHL wrote: Mon Feb 06, 2023 1:49 am
Ralph P.
Greetings,liamtoh1 wrote: Wed Feb 08, 2023 9:40 pmDid you explore this utility? I did not find any comprehensive documentation regarding various options. I see the explanation at high level but wary of causing long term harm to the drive, by say going to "High Performance Mode". In my case, the "Setting 1" tab is disabled.Ralph P. wrote: Wed Feb 08, 2023 8:32 pm I recommend downloading the Pioneer BD-Drive Utility from their website as it allows customization of the drive's performance.
I have explored it. It's model specific and would more than likely not harm the drive with any of its various settings options.
liamtoh1
Thanks. I will try to explore it when I get a chance.Ralph P. wrote: Thu Feb 09, 2023 2:56 pmI have explored it. It's model specific and would more than likely not harm the drive with any of its various settings options.liamtoh1 wrote: Wed Feb 08, 2023 9:40 pmDid you explore this utility? I did not find any comprehensive documentation regarding various options. I see the explanation at high level but wary of causing long term harm to the drive, by say going to "High Performance Mode". In my case, the "Setting 1" tab is disabled.Ralph P. wrote: Wed Feb 08, 2023 8:32 pm I recommend downloading the Pioneer BD-Drive Utility from their website as it allows customization of the drive's performance.
