karbre
Post by karbre » Sun Feb 05, 2023 10:47 pm
from the 1.17.3 release notes:
"DV HEVC streams with certain encoding were processed in a non-compatible way"
is there any more info on this? especially on how to differentiate UHD discs of which previous versions produced faulty output.
quietvoid
Post by quietvoid » Mon Feb 06, 2023 12:35 am
Donpoku wrote:
Sun Feb 05, 2023 10:19 am
I see then what do you use with those files? Thanks.
I don't watch high bitrate files.
It fixes a bug I've reported that made resulting video bitstream incompatible with FFmpeg (the Dolby Vision RPU wasn't parsed by FFmpeg for affected MakeMKV outputs).
I don't think it affects playback otherwise.
There's no easy way to know if the output is bad.
I'm only aware of maybe 2-3 discs affected.
jayper
Post by jayper » Mon Feb 06, 2023 3:01 am
hell001 wrote:
Sat Feb 04, 2023 9:15 pm
johnjon94 wrote:
Thu May 12, 2022 8:48 pm
I meant in regards to movies that don't have IMAX DV WEB-DL releases but have an IMAX HDR WEB-DL, like Spider-Man Far From Home.
Also wondering about this same film, as well has No Way Home. I've seen a few IMAX hybrid releases where the uploader credits the DV layer from a non-IMAX release, and am unsure how this is possible. Can non-IMAX Dolby Vision sources create legit IMAX hybrids? To my knowledge neither FFH nor NWH have IMAX DV releases.
(Note: I am not talking about generating it yourself with Davinci Resolve or some other method.)
I might be wrong, so an actual expert should weigh in, but to my knowledge it is possible to extract an RPU from any DV release. The resolution does not have to match the HDR10 base layer file's resolution.
Balthazar2k4
Post by Balthazar2k4 » Mon Feb 06, 2023 12:59 pm
I know it fixed my StudioCanal copy of Bill & Ted's Excellent Adventure.
staknhalo
Post by staknhalo » Mon Feb 06, 2023 9:08 pm
Can anybody confirm if they can or can't replicate if they have nothing better to do - constant RPU misalignment if you simply remux with ANY DV5 release of Glass Onion (noticeable throughout but when the three way call goes on screen when trying to open the box, you notice in obviously in bottom left IIRC), and the DV8 release of Pale Blue Eye (1080p marked as HDR only), and Community (TV series) DV8 - with Community it actually looks like there are RPU alignment artifacts encoded into the BL? I was able to mux out the RPU for Pale Blue eye leaving me with an HDR only that was fine, but when doing that on Community BL still had artifacts.
Scenes are also pre-making DV8 from DV5 + HDR10 now but only labeled HDR in file name only :/ wish they'd stop and just stick to DV5 + HDR10 separate
Edit: Pre muxed D+ are fine, just NF titles all issues just simply remuxing
hell001
Post by hell001 » Thu Feb 09, 2023 1:54 am
I’ve heard similar, where you can use say a 1080p DV layer and inject it into a 2160p HDR file. But in those cases the aspect ratio is the same. I wasn’t sure if this also applied to IMAX, specifically with the IMAX release having extra content on the top and bottom. Does the non IMAX DV layer know how to handle that considering its source file doesn’t have that? And produce the same result as if it was coming from an IMAX DV layer?
johnjon94
Post by johnjon94 » Thu Feb 09, 2023 3:47 am
Unfortunately it's not possible. The DV metadata from a non-IMAX source won't have the necessary information for the extended aspect ratios in the the IMAX scenes.
johnjon94
Post by johnjon94 » Thu Feb 09, 2023 3:48 am
Unfortunately it's not possible. The DV metadata from a non-IMAX source won't have the necessary information for the expanded aspect ratios in the the IMAX scenes.
staknhalo
Post by staknhalo » Thu Feb 09, 2023 6:04 pm
On Bravia Core they do
edit: FFH HDR10 IMAX NWH DV8 IMAX
jorgen
Post by jorgen » Fri Feb 10, 2023 3:42 pm
The best way to play FEL titles is using a physical player (for instance Oppo) with M2TS/TS or BDMV/ISO files. When you create a mkv with Dolby Vision from a UHD disc, is it possible to reverse the process and create a Blu-ray structure from a mkv file and not lose any Dolby Vision information?
Converting can be done with https://github.com/justdan96/tsMuxer
Skinny Pete
Post by Skinny Pete » Sat Feb 11, 2023 9:53 am
How to switch from Dolby Vision profile 8 to 5
I have this file that has: HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible. I just want to have a file that can be played properly on my TV. A file with: HDR: Dolby Vision, version 1.0, dvhe.05.06, Bl+RPU is reproduced correctly, so I think the first is DV profile 8, the second profile 5. How do I go from 8 to 5 in mp4? Maybe I am doing it wrong and they are not the right profiles, you tell me what I should do.
yossSP
Post by yossSP » Sat Feb 11, 2023 7:09 pm
RESET_9999 wrote:
Wed Jan 25, 2023 10:46 pm
yossSP wrote:
Wed Jan 25, 2023 10:39 pm
Hi all, I'll launch a question to @RESET_9999 and every other member of this forum.
There's a guy in other forum of my country where I'm in who claims that the FireTV Stick 4K (2018 version) can now playback Dolby Vision FEL titles.
As far as I know there's no FireTV that could playback FEL files using the EL layer. From what I have guessed and taking into account that the guy is basing his claim on viewings with naked eye, this device is playing FEL titles as MEL (without using EL layer), what already has a great quality as is.
Could anybody confirm or deny this statement?
He's probably talking about quietvoid's new kodi build that can play P7 as P8. Read just a couple comments above.
Thanks for your answer, but I think he's playing directly with Plex.
He says that before, when he tried to play with Firestick FEL titles could only get a black screen.
yossSP
Post by yossSP » Sat Feb 11, 2023 7:14 pm
quietvoid wrote:
Thu Jan 26, 2023 1:38 pm
My 2018 4K stick hasn't been updated in years but it never could play FEL, blank screen.
The 2021 4K Max behaves the same, with latest firmware.
Thanks for your answer @quietvoid, this guy says that before, when he tried to play with Firestick FEL titles could only get a black screen, as you confirmed, but now It could play FEL titles with the TV Dolby Vision Logo enabled.
As I said before I think this device is playing FEL titles as MEL (without using EL layer) but... could It be a good time to update your ancient 2018 Firestick and give it a try? ;)
quietvoid
Post by quietvoid » Sat Feb 11, 2023 7:26 pm
I'm not updating it, no.
yossSP
Post by yossSP » Sat Feb 11, 2023 8:00 pm
Ok, of course, but i'm intrigued why are you so sure and categorical. It's because new firmwares are worst in certain aspects?
