I want to be able to double click an ISO file in windows explorer and have it load into MakeMKV.
I have associated .iso files with makemkv.exe but it only opens an empty MakeMKV without loading the file.
Please advice.
Thank you.
Opening ISO files from windows explorer
- Contact:
Re: Opening ISO files from windows explorer
It's not possible now. Thanks for suggestion, will try to add in the next version.
Thank you for the quick reply. I look forward to seeing it implemented
Cheers.
Cheers.
