v1.17.2 -- Converting mkv to mp4 with ffmpeg generates a bad mp4 file
tyndale
Post by tyndale »
Hi, I can generate an mkv with the mac version of MakeMKV beta. The problem is when I try to convert it to mp4 and the generated mp4 can't be opened.
both
ffmpeg -i B1_t00.mkv -codec copy out.mp4
and
ffmpeg -i B1_t00.mkv -c:v copy -c:a aac -b:a 128k out.mp4
don't generate a usable mp4.
Any ideas?
Re: v1.17.2 -- Converting mkv to mp4 with ffmpeg generates a bad mp4 file
Are you sure whatever video and audio codecs are present in your source .mkv file are supported by the .mp4 container AND supported by your player software?
MP4 file format @ Wikipedia
Change video file container to mp4 @ Stack Overflow
