LibreDrive for Pioneer drives
xt3n5i0n
Post by xt3n5i0n » Fri Feb 03, 2023 6:06 am
Got a BDR-UD04, weird firmware 1.21, got a different signature to the other UD04 (ID19 vs GENERAL), couldn't even flash to 1.14
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.21
Serial number: ------------
Firmware date: 2018-04-26
Highest AACS version: 60
Drive platform: Pioneer RS8A10
Firmware version: ID19
Blackened2687
Post by Blackened2687 » Fri Feb 03, 2023 7:00 am
xt3n5i0n wrote: Fri Feb 03, 2023 6:06 am Got a BDR-UD04, weird firmware 1.21, got a different signature to the other UD04 (ID19 vs GENERAL), couldn't even flash to 1.14
Revision: 1.21
This is Fujitsu OEM firmware. You will need to send the dump generated by MakeMKV to Mike so he could add support for this version.
xt3n5i0n
Post by xt3n5i0n » Fri Feb 03, 2023 7:59 am
Blackened2687 wrote: Fri Feb 03, 2023 7:00 am
Revision: 1.21
I already did, fingers crossed it can be done. Also I noticed if I plug the drive in an Initio box, the firmware data doesn't show up in MakeMKV, does anyone know if initio chipset prevents libredrive being used?
Edit: got a BU40N as well, works flawlessly in the Initio USB3 box.
ekrunch
Post by ekrunch » Fri Feb 03, 2023 6:40 pm
An update on my BDR-S13U-X drive. I loaded up 1.17.3 and voila! Working great now. Note : I haven't tested MakeMKV backup directly yet as I'm still using AnyDVD HD w/ LibreDrive support.
Shout out to the devs for making this update and turning it around so quickly. I just purchased MakeMKV and appreciate all the hard work that goes into this tool!
OS device name: F:
Current profile: BD-R SRM
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: BKDL300033UC
Firmware date: 2022-07-26
Highest AACS version: 77
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
ekrunch
Post by ekrunch » Fri Feb 03, 2023 6:43 pm
EwokZilla wrote: Sun Jan 29, 2023 7:50 pm
Possibly a stupid question. I'm fairly new here but purchased a BDR-S13U-X, which is showing up today. I noticed someone sent in the file for that model recently. What are the chances that it's already been added? Thanks for all you do!
See my above post. MakeMKV 1.17.3 is out and supports this drive with the 1.03 firmware on it.
MasterControl
Post by MasterControl » Sun Feb 05, 2023 5:28 pm
Not working anymore with Pioneer BDR-S13JX after upgrading firmware from 1.03 to 1.04.
MakeMKV v1.17.3
Post by Coopervid » Sun Feb 05, 2023 5:32 pm
See my reply to your other post.
MasterControl
Post by MasterControl » Sun Feb 05, 2023 5:38 pm
Coopervid,
Got it, thanks for your help!
zaqqaz6917
Post by zaqqaz6917 » Sun Feb 05, 2023 10:37 pm
Hello All
I am new here and very glad to be here.
Bought 2 yesterday on Feb4,2023
PIONEER BDR-S13UBK from Amazon USA seller Pioneer USA
One drive had fw 1.03 and using makemkv worked well
Other drive was fw 1.04
OS device name: H:
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number: BJDL300047UC
Firmware date: 2022-12-12
Highest AACS version: 76
Firmware version: ID43
After reading all info before posting I am sending the dump to admin Mike
If this dump has already been sent I apologize in advance
Thank you for such a great product and support forum; Kudos to the tireless members who so freely offer their time and knowledge.
zaq
ssmokeyy
Post by ssmokeyy » Mon Feb 06, 2023 1:28 am
I also have the PIONEER BDR-S13UBK with 1.03 firmware and it has errors and encryption problems with 4k uhd disc. Works normal with just normal bluray. Is there a firmware problem or something else? Also I have sent a dump file to Mike. How long does it normally take for him to update or get back to u about this?
Post by d00zah » Mon Feb 06, 2023 2:03 am
ssmokeyy wrote: Mon Feb 06, 2023 1:28 am I also have the PIONEER BDR-S13UBK with 1.03 firmware and it has errors and encryption problems with 4k uhd disc. Works normal with just normal bluray. Is there a firmware problem or something else? Also I have sent a dump file to Mike. How long does it normally take for him to update or get back to u about this?
As long as 'Enable internet access' is checked on the Preferences > General tab, you will automagically pick up the update when available. You'll know when MakeMKV reports it in the 'LibreDrive Information' section.
N00B731O
Post by N00B731O » Mon Feb 06, 2023 7:13 pm
Just joined to note that my 1.00 firmware Pioneer 212UBK works with MakeMKV natively for the list of compatible drives (I don't think the firmware dump is necessary but happy to provide given my drive was never updated).
OS device name: E:
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: SFDL000029WL
Firmware date: 2019-01-10
Highest AACS version: 65
Drive platform: RS8F01
Firmware version: 1.00/ID58
Still runs at ~4x speed (I think technically 3.9, but I do recall it going to 4.0 when I did a test rip), interestingly enough compared to newer revision firmware.
LuxWulf
Post by LuxWulf » Tue Feb 07, 2023 1:04 pm
Hi guys, first time here.
You'll have to forgive my lack of knowledge, I've just picked up a BD-RW BDR-XD07TS and not sure if It can do UHD or not.
From research I've done people are saying the TS model is just a Tiwanese version of the XD07 but theres nothing about UHD support anywhere.
OS device name: E:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: BBDL011055WL
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 56
Drive platform: RS8D30
Post by Billycar11 » Tue Feb 07, 2023 4:56 pm
LuxWulf wrote: Tue Feb 07, 2023 1:04 pm Hi guys, first time here.
OS device name: E:
Revision: 1.03
No that does not do UHD it will need to be flashed email me for the pioneer autoflasher
G21_Goose
Post by G21_Goose » Tue Feb 07, 2023 5:09 pm
Hello everybody,
I am brand new into your community. Today I have tried to use my Verbatim drive to encode UHD. unfortunately it's dosen't work has excepted. I have tried on Linux and Windows. As I can seen in windows, my device seems to be supported by LibreDrive, but it dosent see any disk into my MakeMKV, Could be possible that I have missing something ?
Many thanks in advance and a Big "Merci" for all your valuable works for this project
