The Green Mile Illegal Request
trevork99
Post by trevork99 » Sun Jan 22, 2023 4:01 am
Usually my drive is very good when it comes to ripping UHD discs (I have an ASUS BC-12B1ST flashed with LibreDrive 3.01 and it's worked very well for almost all of my purchased discs) but this disc I recently got, The Green Mile, seems to be causing issues.
The disc is 99% flawless in how it looks, but when I put it into the drive and try to rip the movie file it fails at 25% every time and I receive this error:
Saving 1 titles into directory G:/
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '22948737024'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '22948737024'
Failed to save title 1 to file G://Green Mile_t01.mkv
0 titles saved, 1 failed
I have cleaned the disc as recommended (wiped the disc center-to-edge with a damp microfiber cloth and dried off with another one), restricted my drive's read speed via regedit (0=99;U3=-), and I still seem to get this error. This is a triple-layer disc as the files are over 66GB. Could it be that this is simply a bad disc or is there something else I should try?
EDIT: It seems that trying to back up the disc throws errors as well. Here's what was happening before I stopped it:
Backing up disc into folder "G://Green Mile, The"
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while issuing SCSI command 28080..001 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02BC44463CC17EE695B347AB360F79A466A to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0198E1661E92E1CB0415CC82EDCE9C5B0D8 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00BEC15AEA92D34D365F9B5DDED3CB5B509 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01CECA749533820024DC55E65B791BCE388 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CE8ED854F63A22EFFF490D281FAE7B3904 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0314D8FEA879927DB10D9EA45C3695140D2 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..046FFEF9C7C81A33CF1378BF5943DF26BDC to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DB6EB9878479E2E9B456061B9FB17DDF8E to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CF2020FDE413CB2EAA67D02B08A4AB7D77 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..050D0B1328CF97F6082A81FD2F37580A0BC to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03A94EC2047B5F24CB62C57E36C5D28A5B8 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..009606CDEC30D53EF53854FFCD505CA39B4 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05F87CED704C24F2F464847A5DBD915406A to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D3A5515F933B7E535CA3C6B1CBC9493546 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0252AFCE7F9EC5B268B84FF9612B582665B to device 'SPTI:\Device\CdRom1'
Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ASUS BC-12B1ST b 3.01 KETI6JH0314' at offset '5046272'
Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ASUS BC-12B1ST b 3.01 KETI6JH0314' at offset '5103616'
Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-ROM ASUS BC-12B1ST b 3.01 KETI6JH0314' at offset '158138368'
Saved AACS dump file as C:\Users\trevo/.MakeMKV/MKB20_v76_GREEN_MILE_3599.tgz
Backup failed
So I see authentication errors. Is it possible that a dump for this disc was not yet submitted? I don't see a topic on this forum regarding it.
krutoileshii
Re: The Green Mile Illegal Request
Post by krutoileshii » Mon Jan 30, 2023 12:45 am
Getting the Volume Key is Unknown. Submitted the dump
lukeyrada
Post by lukeyrada » Wed Feb 01, 2023 6:06 pm
I ripped the same film 4k the other day with zero issues so good luck to you. I use a Pioneer BDR-XD07TUHD.
trevork99
Post by trevork99 » Thu Feb 02, 2023 4:08 pm
So a dump for this release was submitted, but I'm still getting this error plus read errors when I try and back it up.
Ripping the movie file:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '22970234880'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '22970234880'
Making a backup:
Using LibreDrive mode (v06.3 id=31B635E3F921)
Backing up disc into folder "G://backup/GREEN_MILE"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '22952214528'
Failed to save title /BDMV/STREAM/00002.m2ts to file G://backup/GREEN_MILE/BDMV/STREAM/00002.m2ts
Encountered 4 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 1 files failed hash check
I give up. I'm just gonna go ahead and buy a new disc.
adamthefilmfan
Post by adamthefilmfan » Fri Jun 09, 2023 6:35 pm
I'm getting the same Volume Key is unknown. How do I submit an error log file?
My drive is :
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Post by d00zah » Fri Jun 09, 2023 6:46 pm
adamthefilmfan wrote: Fri Jun 09, 2023 6:35 pm I'm getting the same Volume Key is unknown. How do I submit an error log file?
My drive is :
Revision: 1.14
From the UHD FAQ:
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com"
Make sure Preferences > General tab > 'Enable internet access' is checked.
