Update for Linux version???
jtreagan
As near as I can tell, you haven't upgraded the Linux version of MakeMKV since 2009? I installed that version on my Linux computer a couple of years ago and it works really well. However, now it's telling me that it is out of date (well, yeah!). A couple of days ago I found the registration code and re-registered it and that day it worked fine. Today, when I started it up it told me, once again, that my version was too old. How do I update this?
Re: Update for Linux version???
Each update applies to Mac, Windows, and Linux. So there is a "1.17.2" for all three.
I'm not sure when MakeMKV complains about the "out of date" for a registered version, though. I've been running various versions on my machines here from 1.14.x to 1.17.x without a complaint OTHER THAN when it checks to see what the current version is.
lart2150
Yes, but the current serial number message ( viewtopic.php?f=5&t=1053 ) states that the code is good "is valid until end of January 2023."
So the current beta code isn't working, so the original code jtreagan had needs to be in place. What is in the Linux library (all versions, really) is what was a current beta code when the version was released... That's what is probably complaining. Getting the proper code should fix it.
