AVCHD to MP4
SEANDAVEY
AVCHD to MP4
Post by SEANDAVEY » Sun Jan 29, 2023 7:54 pm
Some Help. I found previous posting on how to fix this. But it says run an AVCHD procedure. I look high and low for this procedure. If anybody has the that post or an archived post to share. Would be grateful. Thank you.
MakeMKV v1.17.2 win(x64-release) started
Downloading latest SDF to C:\Users\George/.MakeMKV ...
AVCHD metadata found
File 00000.mpls(1) was added as title #0
Failed to parse AVCHD metadata embedded by your camera, please report it on http://www.makemkv.com/forum/
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Re: AVCHD to MP4
Post by dcoke22 » Tue Jan 31, 2023 5:01 am
I assume it is what is described here: viewtopic.php?p=3017#p3017
or here: viewtopic.php?p=33069#p33069
What camera did you use to record that video?
SEANDAVEY
Re: AVCHD to MP4
Post by SEANDAVEY » Thu Feb 02, 2023 12:26 am
SONY HDR-CX160
I tried another route. Went in to makemkv View: Preferences and changed the 120 to 0 on Min Title Length. This seem to work.
Thank you again for your quick reply.
