powdeau
#7936 Post by powdeau » Sun Jan 29, 2023 4:43 pm
RESET_9999 wrote: Sat Jan 28, 2023 7:52 pm
powdeau wrote: Sat Jan 28, 2023 4:51 pm What if the movie has only 100 nits or only 600 nits trim pass, would that be a problem?
100nits = AFAIK it's not used in DV playback but it is used with Windows 10 Movies&TV app when tone mapped to SDR. So when the movies only has 100nits trim, its the same has no trims for DV playback.
600nits= definitely has an effect on my C2, in fact, all the trims work together at the same time. I used to think that only one trim was selected but it's not the case at all.
pattern to see what I'm talking about:
https://drive.google.com/file/d/1wgph-I ... share_link
Thank you, you were right about 600nits trim pass taking an effect.
So I guess if a movie has only 100nits trim pass, it's better to generate new DV metadata with Resolve (if using C1 + x700).
If I convert a HDR10+ to DV, is it possible to additionally add trim passes?
#7937 Post by RESET_9999 » Sun Jan 29, 2023 4:56 pm
powdeau wrote: Sun Jan 29, 2023 4:43 pm So I guess if a movie has only 100nits trim pass, it's better to generate new DV metadata with Resolve (if using C1 + x700).
No, the only reason you should generate DV instead of using the official dv source is if the L1 plot and PQ comparison clearly show that they are not the same grade. (speaking of hybrid p8 remux of course)
now if the content has high L1 max_pq values and is "L1 no trim" or "L1 + 100nits trim only", there may be an issue with the x700/x800m2/oppo which seem to have no reaction to higher values but this is has nothing to do with generated DV.
Well not sure why you would want to do that but the dovi_tool has a function that can copy the metadata from one rpu to another but I believe the shots must be the same.
Anyway, i dont recommend converting HDR10plus anymore see my response here:
viewtopic.php?p=131307#p131307
powdeau
#7938 Post by powdeau » Sun Jan 29, 2023 5:11 pm
RESET_9999 wrote: Sun Jan 29, 2023 4:56 pm No, the only reason you should generate DV instead of using the official dv source is if the L1 plot and PQ comparison clearly show that they are not the same grade.
So to avoid that issue with x700, isn't it better to generate new DV that will have trim passes instead of using the official one without any trim passes?
#7939 Post by RESET_9999 » Sun Jan 29, 2023 6:24 pm
powdeau wrote: Sun Jan 29, 2023 5:11 pm So to avoid that issue with x700, isn't it better to generate new DV that will have trim passes instead of using the official one without any trim passes?
No, the default resolve trim passes have a too strong/undesired effect when the content is very bright. When the studios grade DV, the L2 trims are edited manually shot by shot after the algo generated the default values.
This is why I overwrite them if you use my script to inject an XML file.If you go back a couple of pages, I posted a pattern that shows exactly that.
ben_uk
#7940 Post by ben_uk » Mon Jan 30, 2023 12:40 pm
Hi, bit of a newbie here still, so forgive the questions...
Up until this point had just been using MakeMKV in this way;
Insert disc > Open MakeMKV > File > Open Disc > Then ticking the appropriate film title(s) > Then hitting makemkv
I understood this method to backup everything including the DV layer. I don't have a capable player currently of playing DV, but I thought that when I did get one (soon) all my film rips would be useable with DV, having read through some of this thread, I don't think that is possible?
Is the above method the correct way of capturing a film? I thought I read somewhere that the m2ts files are a better approach for displaying DV content, but that means you have to do a complete backup of every disc?
#7941 Post by RESET_9999 » Mon Jan 30, 2023 3:24 pm
@quietvoid.
Wow the new plot function in your dovi_tool is amazing. Soooo much faster than the python script.
thanks a lot
kazuma
#7942 Post by kazuma » Mon Jan 30, 2023 5:12 pm
RESET_9999 wrote: Mon Jan 30, 2023 3:24 pm @quietvoid.
thanks a lot
indeed, phenomenal job again from reset_9999.
powdeau
#7943 Post by powdeau » Mon Jan 30, 2023 5:16 pm
RESET_9999 wrote: Sun Jan 29, 2023 6:24 pm
I see, so to avoid that issue, it is best to just extract the original XML file and run it through your script, which will add the missing trim passes.
#7944 Post by RESET_9999 » Mon Jan 30, 2023 5:41 pm
I updated the scripts(6-2-3)(6-2-2) to reflect the awesome new plot option in the latest DoVi_tool. Python is no longer required.
#7945 Post by RESET_9999 » Mon Jan 30, 2023 5:46 pm
powdeau wrote: Mon Jan 30, 2023 5:16 pm I see, so to avoid that issue, it is best to just extract the original XML file and run it through your script, which will add the missing trim passes.
extract original XML ? i dont think the dovi_tool can do RPU to XML.
If you mean the generated resolve XML, then yes IMO you should always overwrite the default trims with my script or manually.
powdeau
#7946 Post by powdeau » Mon Jan 30, 2023 5:59 pm
RESET_9999 wrote: Mon Jan 30, 2023 5:46 pm
I'm sorry, I didn't explain myself properly. What should I do, if I have a DV Blu-ray without trim passes and I want to avoid the issue with x700? How can I add those trim passes using your script?
#7947 Post by RESET_9999 » Mon Jan 30, 2023 6:03 pm
powdeau wrote: Mon Jan 30, 2023 5:59 pm I'm sorry, I didn't explain myself properly. What should I do, if I have a DV Blu-ray without trim passes and I want to avoid the issue with x700? How can I add those trim passes using your script?
there's nothing you can do about it.
There's no point in adding blank trim passes and it wouldnt make any difference with the x700 that may have issues with high L1 values.
ragico
#7948 Post by ragico » Wed Feb 01, 2023 5:24 pm
quietvoid wrote: Fri Jan 27, 2023 1:23 am
ragico wrote: Thu Jan 26, 2023 11:55 pm Sorry no. All my P7.ts are from Dovi Fel on purpose. None is from a Mel. And I can assure you that they worked and played perfectly. Unfortunately I did not keep that version.
I don't know but it doesn't add up. I tested a version from the day before and it's also crashing with my test files.
You're welcome to try it: https://mega.nz/file/pZln1IhT#QlMIyPOhW ... 6LidHO1Xqg
This one is the old org.xbmc.kodiDV package.
I don't have the 2023-01-23 build anymore.
Anyways, I have to rework the code so that it works for all files.
This is just temporary.
Reworked code version not ready yet?
quietvoid
#7949 Post by quietvoid » Wed Feb 01, 2023 5:31 pm
ragico wrote: Wed Feb 01, 2023 5:24 pm Reworked code version not ready yet?
No, don't hold your breath.
ragico
#7950 Post by ragico » Wed Feb 01, 2023 5:57 pm
quietvoid wrote: Wed Feb 01, 2023 5:31 pm
Sorry
