If you're experiencing rip errors, please read here first!
protectron
Re: If you're experiencing rip errors, please read here first!
Post by protectron »
Baggi0 wrote: Sun Apr 04, 2021 2:09 pm I'm getting troubles with the new World of Wong Kar Wai Bluray boxset. Most of the discs don't rip and they each behave the same way when they freeze. Often, MakeMKV leaves no message at all. When it does it's something about corrupt files. I know I'm not the only one getting these issues. New unsupported form of protection or should I replace the discs?
My Wong Kar-wai discs aren't working either. I'm using an LG WH14NS40. Did you ever get them to work?
newoski
Post by newoski »
I received the following errors, but the rip completed successfully. Anything to be concerned about or can I trust that the process completed successfully?
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8897949696'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8898281472'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8898410496'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '8898410496'
Jannisberry
Post by Jannisberry »
What Does ILLEGAL REQUEST:INVALID FIELD IN CDB mean
Brand new Disc and cleaned with windex plus microfibre towel error was before and after
jase52476
Post by jase52476 »
The source file '/BDMV/STREAM/00006.m2ts' is corrupt or invalid at offset 18586275840, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00006.m2ts' (title #-) , future messages will be printed only to log file
1 titles saved
Sorry if this has been answered already, but if the title eventually gets copied successfully, does it mean it's fine? There were a lot of these messages and it tried to do the workaround to different offsets about 3 or so times and then eventually said future messages will be printed only to log file (but I cannot locate these logs).
The brand new disk had a sort of haze on it, and I managed to clean it off, but the errors did not go away. Wondering if I should seek a replacement disc or not or if everything worked out.
I played the mkv file briefly, in different spots, and everything seems fine.
jase52476 wrote: Mon Jan 16, 2023 9:12 am
1 titles saved
MakeMKV prints out where the log file is being saved at the top of the output window. It is usually the second line of output.
Usually, if MakeMKV produces an output file, then the rip was successful. If it encounters an unrecoverable error, you won't get an output file at all.
jase52476
Post by jase52476 »
dcoke22 wrote: Tue Jan 17, 2023 3:32 pm Usually, if MakeMKV produces an output file, then the rip was successful. If it encounters an unrecoverable error, you won't get an output file at all.
Thank you. Glad it's OK, because it's long past time I could try to get a replacement disk.
ember1205
Post by ember1205 »
The log file for the rip should show the final status, too, along with the reason it finally "gives up" if it doesn't make it to the end.
Cartigan
Post by Cartigan »
I copied the data off the disc and tried to make an MKV from the local disc and it is still failing with hascheck errors and "corrupt or invalid at offset" errors
What did you use to "copy the data"? Did it report any errors?
MakeMKV is designed to read directly from the Bluray, so you don't have to copy the BD to the local disk. Doing so disables MakeMKV's ability to re-try reads on parts of the disk that might "copy" to the hard drive, but not actually be what was seen on the disk. Some BD drives default to sending "most likely" contents during reads that have errors.
Cartigan
Post by Cartigan »
Woodstock wrote: Thu Feb 09, 2023 1:29 pm What did you use to "copy the data"? Did it report any errors?
I copied the disc two ways. The last way to an ISO, extracted the ISO, and copied over the blu ray decryption file as indicated in other directions. Reading that from my local disc results in errors. The same errors I got when trying to rip it from the disc directly.
Neither file copying software generated errors, nor does playing the movie from disc with VLC.
Cartigan wrote: Mon Feb 13, 2023 9:52 pm I copied the disc two ways. The last way to an ISO, extracted the ISO, and copied over the blu ray decryption file as indicated in other directions. Reading that from my local disc results in errors. The same errors I got when trying to rip it from the disc directly.
MakeMKV, unlike most everything else, uses the built-in hash data on a blu-ray to verify that what it has read off the disc is correct. It only produces output when it has verified that all the data it has read is correct.
A stand alone blu-ray player generally doesn't check. It blows past errors, hoping they're small enough that you don't notice or quickly forget. Using other software on your computer to copy a disc probably didn't check either. So, if the drive read incorrect data, for whatever reason, when you were making an ISO, MakeMKV will detect that error when reading from the ISO.
This feature of MakeMKV is one of its greatest strengths. It is also occasionally maddening. :)
Cartigan
Post by Cartigan »
That's all well and good. How do I get it to read my disc? How do I know if it's valid errors or not?
Local machine:
DEBUG: Code 373 at zbL_5>@rt`]2L>~L$^Xa:29394758
DEBUG: Code 374 at zbL_5>@rt`]2L>~L$^Xa:29394758
DEBUG: Code 375 at zbL_5>@rt`]2L>~L$^Xa:29394758
DEBUG: Code 376 at zbL_5>@rt`]2L>~L$^Xa:29394758
DEBUG: Code 28 at zbL_5>@rt`]2L>~L$^Xa:213133250
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:213131157
DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:213131272
DEBUG: Code 3645729 at ;A,PZPR7U;07xNLh*7.1:121261773
DEBUG: Code 0 at vIu:"0dZYGN8[CIR=_%gF:213129984
DEBUG: Code 0 at *M=d>ww icjnMH% jWIDk:213137068
DEBUG: Code 2 at [y`X9mT%RaeY;:Ul:213132537
Failed to save title 0 to file J:/Video/Teenage Mutant Ninja Turtles/Teenage Mutant Ninja Turtles_t00.mkv
Encountered 2 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Disc:
DEBUG: Code 428 at M3/FTQ1OhsW1YljX41~D:29394758
DEBUG: Code 429 at M3/FTQ1OhsW1YljX41~D:29394758
DEBUG: Code 430 at M3/FTQ1OhsW1YljX41~D:29394758
DEBUG: Code 431 at M3/FTQ1OhsW1YljX41~D:29394758
DEBUG: Code 183 at M3/FTQ1OhsW1YljX41~D:213133250
DEBUG: Code 0 at "j%_6%.1kR5STy/6TK+4:213131157
DEBUG: Code 0 at "j%_6%.1kR5STy/6TK+4:213131272
DEBUG: Code 2349000 at "j%_6%.1kR5STy/6TK+4:121261773
DEBUG: Code 0 at C0:uI8.LBlKv"3?xR:)dX:213129984
DEBUG: Code 0 at w3bdtHM'`U+liV<Pv>-|-:213137068
DEBUG: Code 2 at \Ko,!f\:rW9S;w!E:213132537
Encountered 16 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Slottedpig
Post by Slottedpig »
Hi all,
New to the forum but not to ripping discs. Ive used Makemkv to rip dvd/bluray without issues for years. Im moving into uhd discs and most rip fine but there are a few that ive had to play with to get ripped but there are 2 in particular that i cant get to work at all. Is this a drive issue or is this a bad disc issue. To be clear even if i have a disc that wont work i can put a different one in and it rips fine. I have a usb bu40n and an internal asus 16wdt that i flashed using the firmware from these forums. The asus is on 3.02 and the bu40n is on 1.0.
wnbronx
Post by wnbronx »
iam getting volume key unknown. please advise. thaks
wnbronx wrote: Tue Feb 21, 2023 8:44 pm iam getting volume key unknown. please advise. thaks
Gee, which of a hundred different reasons should we guess at?
Some information would be wonderful.
