SATA UHD Drive, sometimes hangs loading
webminster
Post by webminster » Sat Jan 28, 2023 11:58 pm
Have a new build of a PC on a Shuttle cube, running Windows 10. I have a couple of UHD drives, one an LG, the other a Asus BW-16D1HT. Both work well for makemkv ripping.
But I've notices that sometimes, makemkv will hang "Loading..." after I insert a 4k blu-ray. Takes a power cycle to get control again. Not sure, but seems like if I insert the disc first, then start makemkv, it tends to not hang like that.
Sorry if this is asked before, but is this a known thing that can be worked around? Let me know if I've missed important info. System is running SATA mode and UEFI boot.
-Alan
Edit: Probably unclear about a couple things... I've tried both drives, they act the same. And I know the drives and the discs are OK.. If I put the drives in an external enclosure and connect via USB3, they work fine.
Re: SATA UHD Drive, sometimes hangs loading
Post by Billycar11 » Sun Jan 29, 2023 1:08 am
Always let windows load the disc then open makemkv otherwise they can fight for control of the optical drive
webminster
Post by webminster » Sun Jan 29, 2023 9:29 pm
Thanks for the reply. How is the best way to determine the timing, wait for disc loading noises, then quiet? You use any heuristics to decide when?
Post by Coopervid » Sun Jan 29, 2023 9:44 pm
When the disc is seen in Explorer.
