Install MakeMKV on Fedora
Falco
Post by Falco » Sat Jan 28, 2023 6:24 pm
Hi Guys
It looks some peoples have issues to install MakeMKV on their Fedora Distribution.
I raised a code many years ago, I would like to share with you.
I use Ansible scripts to complete my Fedora installation and to automatically do some settings.
You can use my scripts from there.
In my git repo, there is an English Readme (README_EN.md) to explain how to use it.
Follow the Readme and if you only want to install MakeMKV comment the file myFedora.yml like this:
roles:
#- bootstrap
#- disable-ipv6
#- softwares
#- asbru-cm
- hb-and-mkmkv-needed-softwares
#- handbrake
- makemkv
#- rescue-boot
#- disable-webcam
You have also myvars.yml you need to be sure both variable are ok with the last version number, like this:
MakeMKV_OSS: makemkv-oss-1.17.3
MakeMKV_BIN: makemkv-bin-1.17.3
In first approach you can also use my code in a virtual machine to see the result.
At the end MakeMKV (compiled) and HandBralke (compiled) will be installed properly on your favorite distro.
Please give me your feedbak too, it is also an opportunity to increase my knowledge and my English.
I hope, I could help someone.
Best regards.
Falco
Re: Install MakeMKV on Fedora
Post by Falco » Mon Feb 20, 2023 5:53 pm
Hi Everyone
No feedback or questions guys ? Don't be shy. :(
I only want to help and progress.
Falco
Post by Falco » Sun Mar 19, 2023 6:05 pm
Hi Everyone
If someone tested it, did you face any issues :?:
stefan1
Post by stefan1 » Mon Mar 20, 2023 4:25 pm
Hi currently i use the flatpak version for makemkv, but I will probably try this out with fedora 38 and do a clean install there. After having a short look at your tasks, why dont you use the ansible builtin modules?
https://docs.ansible.com/ansible/latest ... odule.html
Falco
Post by Falco » Mon Mar 20, 2023 5:53 pm
Hi Stefan1
Thx a lot for your message, I was desperate to have no feedback.
To be honest this code is old and I did not take time to rewrite it from scratch and I didn't think this code at first to share it.
Many new features appears in Ansible with builtin modules regarding repositories, installations or elses ...
For some others builtin modules I thought there were a bit slower compare to non builtin.
Today for example we can use "ansible.builtin.packages" but when I started to learn ansible, it was if I remember "packages" (I am not sure) and
it was slower than using the internal command like apt or dnf when you have a big software listing with many dependences to manage.
It was my feeling at this time. :oops:
I agree builtin modules offer portability and an ansible script can be use on another system or many other reason.
Probably, it will be smart to rewrite all with the current good practice, you are right. I need to take this time one day :wink:
stefan1
Post by stefan1 » Wed Mar 29, 2023 3:24 pm
Hi Falco
Lately I couldn rip a 4k disc with my flatpak makemkv setup. So I wanted to test your ansible script and install it on the system. The following issue occured
➜  ansible-post-install-my-fedora git:(master) ✗ sudo ansible-playbook myFedora.yml
[sudo] password for stefan:
PLAY [localhost] *************************************************************************************************************************************************************************************************************************************************************************************************************
TASK [Gathering Facts] *******************************************************************************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [hb-and-mkmkv-needed-softwares : Verify if RPM Fusion FREE Repository exist] ********************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [hb-and-mkmkv-needed-softwares : Add Repository RPM Fusion FREE] ********************************************************************************************************************************************************************************************************************************************************
skipping: [localhost]
TASK [hb-and-mkmkv-needed-softwares : Verify if RPM Fusion Non-FREE Repository exist] ****************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [hb-and-mkmkv-needed-softwares : Add Repository RPM Fusion Non-FREE] ****************************************************************************************************************************************************************************************************************************************************
TASK [hb-and-mkmkv-needed-softwares : Clean DNF Hanbrake_and_Makemkb] ********************************************************************************************************************************************************************************************************************************************************
changed: [localhost]
TASK [hb-and-mkmkv-needed-softwares : Install Group Packages Development Tools] **********************************************************************************************************************************************************************************************************************************************
TASK [hb-and-mkmkv-needed-softwares : Install Group Packages Development Libraries] ******************************************************************************************************************************************************************************************************************************************
TASK [hb-and-mkmkv-needed-softwares : Install Group Packages X Software Development] *****************************************************************************************************************************************************************************************************************************************
TASK [hb-and-mkmkv-needed-softwares : Install Group Packages GNOME Software Development] *************************************************************************************************************************************************************************************************************************************
TASK [hb-and-mkmkv-needed-softwares : Install Differents Packages in HB and Mkmkv] *******************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Verify if MakeMKV exist] *************************************************************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [makemkv : Create Folder to Compile] ************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Downloading MakeMKV OSS] *************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Downloading MakeMKV BIN] *************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Uncompress BIN Achive] ***************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Uncompress OSS Achive] ***************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Configure] ***************************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Compile MakeMKV OSS] *****************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Make Install] ************************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Create Folder BIN to Compile] ********************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Create File to Compile] **************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Compile MakeMKV BIN] *****************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Delete MakeMKV Folder] ***************************************************************************************************************************************************************************************************************************************************************************************
TASK [makemkv : Create Symbolic Link for VLC - libaacs] **********************************************************************************************************************************************************************************************************************************************************************
fatal: [localhost]: FAILED! => {"changed": false, "gid": 0, "group": "root", "mode": "0777", "msg": "src file does not exist, use \"force=yes\" if you really want to create the link: /usr/lib64/libmmbd.so.0", "owner": "root", "path": "/usr/lib64/libaacs.so.0", "secontext": "system_u:object_r:lib_t:s0", "size": 16, "src": "/usr/lib64/libmmbd.so.0", "state": "link", "uid": 0}
PLAY RECAP *******************************************************************************************************************************************************************************************************************************************************************************************************************
localhost                  : ok=10   changed=6    unreachable=0    failed=1    skipped=15   rescued=0    ignored=0
after checking "/usr/lib64/" there is "libmmbd.so.0" does not exist
any ideas?
After editing the the ansible script to symlink from to "/usr/lib/libmmbd.so.0" Everything worked just fine. But to my curiosity after launching makemkv "help -> about" shows that version 1.17.2 was installed
Falco
Post by Falco » Wed Mar 29, 2023 5:38 pm
Hello Stefan1
Let me check, but please let me know which Fedora version are you using now ?
Execute this line:
ls -alh /usr/lib64/libmmbd.so.0 /usr/lib64/libaacs.so.0 /usr/lib64/libbdplus.so.0
At the end, it must be like this :shock: :
lrwxrwxrwx.  /usr/lib64/libaacs.so.0 -> /usr/lib64/libmmbd.so.0
lrwxrwxrwx   /usr/lib64/libbdplus.so.0 -> /usr/lib64/libmmbd.so.0
-rw-r--r--        /usr/lib64/libmmbd.so.0
"/usr/lib64/libmmbd.so.0" exist or not ?
If you ask ansible to restart playing there, what the result please :
sudo ansible-playbook myFedora.yml --start-at-task "Create Symbolic Link for VLC - libaacs"
Or you can also, do this:
sudo ansible-playbook myFedora.yml -t symlinkvlc
Falco
Post by Falco » Wed Mar 29, 2023 6:03 pm
I rewrote the code to be more Ansible documentation compliant.
I tested all many times without any issue. Be sure you have the last code version.
Back to me if you need help !! :D
Falco
Post by Falco » Wed Mar 29, 2023 6:50 pm
Take care also in file myvars.yml, it is now simplified.
You just need to modify it, like this
MakeMKV_Ver: 1.17.3
Replace 1.17.2 by 1.17.3, that's it.
You probably use an old script version.
Linux version should the same as Windows and Mac version.
To Upgrade Makemkv version, do like this.
sudo mv /usr/bin/makemkv /usr/bin/makemkv-OLD
Replay only Makemkv part.
sudo ansible-playbook myFedora.yml -t mkmkv
And then test "About" one more time.
Falco
Post by Falco » Wed Mar 29, 2023 7:00 pm
Are you using a fresh installation or an Upgraded one ?
What the result for :
hostnamectl | grep -i Architecture
Falco
Post by Falco » Thu Mar 30, 2023 7:15 am
Code "role => makemkv" updated this morning to take care about your architecture x32bits or x64bits. :wink: :D
[Cleaned now]
Don't forget to "git pull" or re-clone the repository.
stefan1
Post by stefan1 » Thu Mar 30, 2023 3:00 pm
Hey,
at first everything is looking good now, correct version and ansible worked without any issues
when fedora 37 was released, i did a fresh install
➜  ansible-post-install-my-fedora git:(master) ✗ hostnamectl | grep -i Architecture
      Architecture: x86-64
I think I had an older installation still present and therefore an old binary was started (or not replaced)
after removing the makemkv/makemkvcon from /usr/bin and replaying ansible after recloning the repo everything worked without issues.
Well done and thanks for all the effort
Falco
Post by Falco » Thu Mar 30, 2023 4:14 pm
It sounds good, thx for your feedback Stefan1.
Like I said, if you need to upgrade into the future version 1.17.4 for example, you will just need to
- Rename this binary /usr/bin/makemkv
- Modify the myvars.yml file
- And Replay only the makemkv role.
Example:
Change myvars.yml content, from 1.17.3 to 1.17.4
sudo ansible-playbook myFedora.yml -t onlymkmkv
Have a nice end of day. :D
Falco
Post by Falco » Wed Apr 19, 2023 5:32 pm
Today I finished to rewrite the code to be more Ansible documentation compliant.
Role libdvdcss is good too now :D
Falco
Post by Falco » Fri Apr 21, 2023 6:52 pm
On a new fresh installation of Fedora 38 on my computer, I faced this issue too.
viewtopic.php?f=3&p=132993
I implemented the correction by replacing the value "av_mallocz_array" with "av_calloc" as nrk666 informed us, and it works fine.
Thx a lot for the information nrk666 :D
